Results 1 to 8 of 8
    6 speed cassette/cog question
    Looking at a cheap 6 speed cassette to caniblize for the 18 tooth gear for my single speed project. Does the 6 speed cassette use the same hub and lockring pattern as the 7,8,9 speed freehub? It says it is Shimano compatable. $8 on sale.
    I think......
    That if it is a cassette it would be the same, but being a 6 speed it might be a freewheel. (just a guess though)
    all hail der Fuhrer Bush
    6 sp.
    some of the earlier 6 sp. cassettes used freehubs with even splines -- no odd size indexing spline. They also had external threads on the upper section and were held on by a threaded first position cog rather than a lockring.
    Nashbar# ns-cst6
    I think I can use this for my project. It has a separate lock ring if the pic is correct. Just want the 18 tooth cog.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by 1niceride
    Just get a Novatec cog for $5-6. Works better cog designed for shifting.
    mtbtires.com
    Timely post indeed.
    I am working with an old 6 speed Shimano SIS cassette. Does anyone know how to get that sucker apart? My newer cassette tool won't fit.
    Not a regular
    Quote Originally Posted by sl33pdirt
    The outer cog should thread on. You'll need two chain whips.
    if'n i'm not mistaken, you can drill the pins out of the back and it'll fall apart nicely. get a bit bigger than the "bolt" head and take it down.
  1. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  2. another 8-9 speed question
    By zrock in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 03:27 PM
  3. Replies: 6
    Last Post: 06-15-2004, 03:13 PM
  4. 9 Speed Hub question...
    By hord in forum Wheels and Tires
    Last Post: 04-28-2004, 07:13 AM
  5. Deore 6 speed derailleur w/ 7 speed?
    By bikerboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2004, 08:39 AM
