58mm BCD 5 bolt chainring...- Mtbr.com
Results 1 to 10 of 10
    Reputation: foxracerdd3's Avatar
    I just bought a 1994/5 Parkpre that was converted to a singlespeed. The chainring is pretty worn and I went looking for a new one. The problem is I can't find a 34t 58mm BCD chainring. All the places I tried only have 22t. Any help would be appreciated. Thanks
    one chain loop
    Reputation: fishcreek's Avatar
    are you sure its 58 and not 94mm or 110mm bcd?
    everything sucks but my vacuum cleaner.
    yes I double checked it. It is the old Shimano STX cranks.
    Attached Thumbnails Attached Thumbnails 58mm BCD 5 bolt chainring...-2007_0318image0021.jpg
    Out spokin'
    Dec 1999
    Quote Originally Posted by foxracerdd3
    Looks like somebody cut the spider down. Best of luck with that.
    --sParty
    disciplesofdirt.org
    nothing to see here
    Reputation: Stevob's Avatar
    I just had a custom chainring made by Cycle Underground in Australia. They state that they can do 58mm BCD 'rings.
    Here's mine...
    I see hills.
    I want to climb them.
    Thanks. I really like the look of these cranks but I might just get a new set because these are proving to be too much of a challenge. Any suggestions on a decent set cheaper than custom ordering a new chainring?
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Check ebay for 110bcd cranks. There are usually Deore DX cranks for 35+shipping.
    Out spokin'
    Dec 1999
    Quote Originally Posted by umarth
    ...and OP will be able to employ the desired 34t ring... which is the smallest generally available for the 110bcd. I say "generally" because if one searches diligently, they can find 33t rings for 110bcd, but depending on crank brand / model sometimes the spider will need to be relieved in order to clear the chain.
    --sParty
    disciplesofdirt.org
    Reputation: itsdoable's Avatar
    Shimano STX used a odd BCD (58) on the granny, and the middle and large ring were bolted to the granny via a carrier. The middle ring was stepped to get it into the correct position, no after market rings were available.
    However, they did have a nice polished finish to them...
    I think Surly sells and adapter for their Mr. Worlys that fits the 58mm to 110. Might work on yours
    ken
