3x7 to 1x7 what front ring 90ís deore lx- Mtbr.com
Results 1 to 8 of 8
    Reputation: injected59's Avatar
    Aug 2016
    I have a 3x7 90ís Diamondback with a Shimano Deore LX crankset up front. Iíve already removed the front derailleur and want convert to a single front with some type of chain guide, but I donít know where to start when shopping for a new middle ring. Oh and sorry if this is pretentious but Iíd like it to be gold colored.
    Thanks chris
    Go to Dirtproject.org to help advocate for MTB awareness and trail expansion in IL and the Midwest #thinkoutsidetheroad.
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    Should be these: https://www.wolftoothcomponents.com/...r-5-arm-cranks
    Double check that these cranks are 94/58 BCD.
    You may have a really hard time finding gold ones since this isn't a currently common spider. But, you should be looking for 94mm BCD 5 arm narrow wide rings.
    Also, you may need to get either spacers or different chainring nuts/bolts if you aren't running a bash guard. A lot of the time, the existing chainring nuts will be too long so you can't fully secure a single middle or outer chainring to the spider.
    One other thing, someone else may be able to comment. The older 7 speed stuff may have had thicker chainrings which would make it tough to find a chain that will work with newer ring up front and an older cassette/freewheel in the rear.
    WTB: Med Bontrager Ti Lite, PM Me...
    Aug 2016
    Quote Originally Posted by jestep View Post
    Ok thanks for all the info I will check on that. I had to google BCD btw
    Aug 2016
    Man I have a measured this like 10 times and Iím getting 90 mm
    I think that's correct. Measure between adjacent ones. 94 should be a hair over 55mm between adjacent ones.
    https://www.sheldonbrown.com/cribsheet-bcd.html
    Aug 2016
    Yes it does measure a bit over 55 when measuring adjacent
    Aug 2016
    OK guys sorry to revive this thread but Iím thoroughly confused and donít want to wait till Monday for wolf tooth open back up. I ordered the 94 mm chain ring drilled out the one hole per their instructions but the other four are threaded and thereís no way for me to get The nut on the back of the chain ring bolts. This may seem like a dumb question but am I not supposed to use the nuts and just loctite the bolts in place. Seems like thatís a no no.
    Aug 2016
    Okay wolftooth got back to me (Friday night @7pm, awesome cust service) they said to use nut and bolt on the one hole that is drilled out and just the bolts on the other four. Sorry to bother all of ya, just figured I shouldnít leave the thread hanging for future searchers.
  1. Help with 3x7 to 1x7 conversion for mom!
    By bigchillcar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2014, 06:05 AM
  2. Switching To 1x7... Front Set Up Questions
    By CharleyGnarlyP290 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-11-2011, 03:30 PM
  3. Looking for non bank breaking 3x7 shifters.
    By TwistedBars in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-11-2011, 04:53 AM
  4. Looking for non bank breaking 3x7 shifters.
    Last Post: 05-09-2011, 09:52 PM
  5. Convert To Ss Or Fix 3x7
    By RIDDICKDUX in forum Beginner's Corner
    Last Post: 04-26-2011, 09:43 AM
