36x22 ???- Mtbr.com
Results 1 to 11 of 11
Thread: 36x22 ???
    120 is offline
    Kicker of Elves
    Reputation: 120's Avatar
    36x22 ???
    I'm wondering if I'm overlooking anything here: This ratio looks perfect for my ability / area. I figure less ground clearance, longer wear life, more chain - heavier (though I figure not by much). Are there other things I'm not considering? These sound huge compared to the norm - at least around here.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Nothing wrong with running a bigger ring and cog. "They" say that it will run smoother. I believe Endless advocates such.
    Reputation: boomn's Avatar
    I'm running 36x22 right now and I like it. It does seem to feel a bit smoother, but it is really just shades of the same color (nothing revolutionary)
    Kiss my Grits!
    Reputation: Chim Chim's Avatar
    bigger is better
    I think the difference of a larger chainring is noticable, for the better.
    I don't have a lot of downed logs to negotiate and the hill I ride are not that steep, or that long, so I can get by with a large chainring and I feel a lot faster and smoother with it.
    Sometimes, with a very strenuous effort, I will fatigue.
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    how steep are the trails that you need such a high ratio?
    "If women don't find handsome , they should at least find you handy."-Red Green
    Quote Originally Posted by nuck_chorris
    36x22 is the same ratio as 32x20 (see here), which is a very common ratio for 29ers. Also 29er gearing is different than 26ers, so this is equivalent to 32x18 on your 26" bike
    Reputation: Brewtality's Avatar
    Running the bigger gears should help improve wear and tear on the drivetrain. More gear teeth in contact with the chain = spreads out the load = parts last longer
    Its all Shits and Giggles until somebody Giggles and Shits
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    I've always tried to stick to bigger cogs, mainly to have more engagement. Slower wear is also nice. I'm currently running 34x19, that is about the smallest I would go in the back. If I want a taller gear I'd grab a bigger front ring.
    Out spokin'
    Dec 1999
    Not a thing wrong with 36x22. Heck, I'm running 36x24.
    --Sparty
    disciplesofdirt.org
    Birthday Collector
    Reputation: ATBScott's Avatar
    Yes - a 36 x 22 would be just a hair taller than a 32 x 20, and just a bit smaller than a 33 x 20. The larger ring/cog will wear about 10% longer, the only downside is that it weighs a bit more if you are a weenie. If it works for your trails and you can climb what you need to, and go fast enough on the flats, do it!
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    120 is offline
    Kicker of Elves
    Thanks all, I have the 22t on its way. Appreciate the info!
