34t Ring for Truvativ?- Mtbr.com
Results 1 to 9 of 9
    Reputation: WadePatton's Avatar
    May 1999
    It's a 4-hole job. A 32t comes on the Bianchi SISS.
    Is there something out there that will bolt on? Truvativ didn't make one last time I checked. And I've been out of the loop for a while.
    I would rather have a bottle in front of me than a frontal lobotomy. W.C. Fields
    Reputation: williamf777's Avatar
    Me thinks that any 4 bolt 104 chainring will work. Spot makes a fresh one. It is very quiet compared to my 36t Salsa. e-13 makes some light rings too.
    You need something like that
    Cheers,
    Maurice
    May 1999
    Thanks. I knew I'd come to the right place. Hmmmm, maybe a 36t too!
    Can you hear my knees screaming?
    i worship Mr T
    Reputation: *rt*'s Avatar
    Quote Originally Posted by Maurice
    Cheers,
    Maurice
    exactly. that's what i'm running on mine. 34t, 4-bolt, team stylo
    rt
    "where are you not going so fast?" (question asked to cyclist on a trainer)
    *rt*'s fabulous blog
    mm blogging
    Fartographer
    Reputation: Photo-John's Avatar
    Aug 2001
    Truvative DH
    I've got a 34 tooth Truvative DH ring on my Truvative cranks.
    Back of the camera, back of the pack.
    Sep 2004
    Hey
    Sorry I don't mean to hijack but with the Truvativ Stylo would it make a difference if I took the bash guard off and ran the ring on the outside of the spyder instead of the inside where the it normally sits. I don't think it would change the chain line all that much, would it?
    Reputation: Nater's Avatar
    It will change the chainline...
    Quote Originally Posted by TrailVictim
    Hey
    Exactly the same amount as the width of the chainring mounting tabs on the crankset. You'll also have to get some shorter, track chainring bolts to run the single ring.
    Fartographer
    Aug 2001
    I done it
    I took the bash ring off mine. Works fine. Like Nater said, you will need some shorter chainring bolts.
  1. 38t big ring for 2*9 application?
    By TeXe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2005, 11:42 PM
  2. 54 42 30 Xc Crankset ? ! ?
    By reisenhaure in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2004, 05:50 PM
  3. middle ring upshift problem
    By gooberhead in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2004, 04:52 PM
  4. chain binds up on smallest crank ring
    By ewarnerusa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2004, 09:23 PM
  5. Missing 4 teeth on big ring == problem?
    By phUnk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-20-2004, 06:28 PM
