32x18 vs 34x19. Pros/cons of either?- Mtbr.com
Results 1 to 15 of 15
    i'd expect the 34x19 to last slightly longer since more teeth are sharing the load but with the possible drawback of more strikes on log hops. otherwise i can't figure out why one would be better than the other. your opinions?
    Downcountry AF
    Oct 2013
    no difference. they're so similar any benefit would be very minimal. yes 34x19 would wear a little slower.
    just for pro/con purposes to add to what you've said: con 34x19 is slightly heavier. see, very minor.
    maybe if it has a very specific application on a certain bike that required a special setup then maybe, but just as one vs the other not a big difference. my .02
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Depends on how strong you are.....
    Based on a 29er with a 2.20 rear tire:
    32x18 = 51.4 gear inches
    34x19 = 51.7 gear inches
    Edit: ooops.....copied the wrong column.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    i see 51.4 vs 51.7 for a 2.2.
    With the 2.4's i run, the calculator says 32:18 = 52.1 and 34:19 = 52.4 so in either case, 0.3 inches difference.
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by head View Post
    You are right, I looked at the wrong column.
    Look at it the same way as would you a 28x16 vs. 32x18 if the ratio was the same? Bigger ring/cog combinations do offer more chain wrap.
    The whole chainring clearance for logs and such....not such a big deal....honestly the couple of extra mm's aren't gonna make that much of a difference in whether you hit something or not..
    Run which ever combo you want.
    Jun 2010
    If you have sliders... see which combo gives you the best chainstay length.
    http://eehouse.org/fixin/formfmu.php...ey=Stay_length
    Armature speller
    Sep 2004
    I like the extra wrap and efficiency of bigger rings. They just feel smoother.
    Reputation: Velobike's Avatar
    If you use a prime number of teeth in a cog or sprocket it theoretically evens out the wear.
    Latitude: 57ļ36' Highlands, Scotland
    Armature speller
    Sep 2004
    Quote Originally Posted by Velobike View Post
    Only if you're getting uneven wear.
    Mar 2015
    Don't you just need the number of rear/front cogs to be relatively prime?
    EDIT: ... to achieve this theoretical, perhaps not practically useful, even-wearing.
    I've noticed this on my geared bike. When I am on any flattish trail, I like to keep it in the big ring (I still run old-school 3-ring with 44). It just seems to spin so much better. I attributed it to the chain being in a much more neutral state as it wraps around the chaingring, but I didn't think it would be enough to feel. Was wondering if there would be the same effect on SS.
    Aug 2010
    Quote Originally Posted by slohr View Post
    I think that is the "smoother" feel mentioned above. I often prefer larger rings within reason.
    Did I catch a niner+?
    In flat MN where we have short punchy climbs I have been running a 34x19 for a year or so and run a 34x18 for races. I think next year I will move to a 34x17 though, I think I am ready to make that move.
    There are a couple guys here running 36x16 though.
    Aug 2010
    I run 32x20 here but it can get really hilly. I tried 36x22 and liked the smoother pedal cycle but even that much gear change made the ride too tough for my weakness.
    Short answer: no difference.
    Long answer: minor advantage to 34x19. The Big Ring ‚Äď Mechanical Or Psychological Advantage? | CyclingTips
    Takeaway: don't worry about it.
    My other bike is a /7.
  1. URT? SS Pros and Cons
    By IBBW in forum Singlespeed
    Last Post: 05-11-2017, 11:59 AM
  2. Carbon rim pros and cons?
    By amirh1 in forum 27.5
    Last Post: 01-08-2014, 09:03 AM
  3. Pros and Cons?
    By Sarguy in forum Apparel and Protection
    Last Post: 05-15-2012, 12:46 PM
  4. Pros-Cons
    By JMac47 in forum Yeti
    Last Post: 12-11-2011, 01:01 PM
  5. DH or FR bike? Pros and cons of each please
    By Boylerules in forum Downhill - Freeride
    Last Post: 11-04-2011, 10:43 AM
