32T to 34T or 36T?- Mtbr.com
Results 1 to 10 of 10
    32T to 34T or 36T?
    I just put my single speed together. I'm going to use it mostly for riding to work which is about 2 miles and pretty flat. Right now I'm using a 32/16 combo because that's what came with my SS conversion kit and new cranks. I spin pretty fast in this combo and would like to have it a little harder to pedal so I won't spin so fast. I was thinking of swapping the front to either a 34T or 36T. Would I notice a real difference with the 34 or would it be better to go with the 36?
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    I take it... 26" or 29"er commuter?
    In that case, (>46):16.
    Mostly depending on gradient of the route to how big a front chaining you can run practically.
    oh yeah, 26"
    Mtbr Forum Sponsor - Homebrewed Components
    you might even want to go bigger than 36t, or smaller than 16t in the rear.
    Again, depending on gradient of the route will affect how much you'll spin or crunch.
    For the relatively flat, without long hills for me to climb; I can play with 80-85 gear inches.
    My SS trekking is 44:14 magic ratio with a half link, on 700x28c. Works out to 84.1GI.
    My old 26"er as a commuter, was 48:16 on 1.5" slicks... a spinny 74.6GI. So to achieve a similar GI as my 700c trekker on the 26"er while running a 16T rear cog, the front chainring would have to be 54T.
    Keep in mind; a one tooth difference in the front can't be felt too easily, but a single tooth difference in the rear will make itself felt.
    so maybe a 38t
    36:16 is a decent short commuter ratio. I'd skip the 34T, unless you want to preserve some offroad capability.
    If your commute was a little longer, I would say 38:16 or even 38:15 fixed.
    I think I may want 36T. It's a short commute and when I'm not riding to work I plan on riding around town and don't want a gear so hard that it's a pain to ride in town. If I take it off-road I can always throw the 32T back on.
    Reputation: ianick's Avatar
    Check out the Sheldon Brown Gear Calculator. It will tell you the speed for a given gear combo/pedal rpm. For instance here is the speed @ 90rpm for a 32/34/36 chain ring and 16 tooth gear:
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I'm more of a fan of 70 gear inches, assuming you are keeping it to (mostly) paved surfaces. It might be because I like to spin, or I don't like having to mash for thirty seconds to get up to speed after a light or stop sign.
    If you are doing some offroad that is flat, run 60.
    If you are doing only paved, think about 170mm crank arms.
