32:16 versus 32:17- Mtbr.com
Results 1 to 9 of 9
    32:16 versus 32:17
    How different is a 32:17 to a 32:16?
    Is it noticable or would I need to change to 32:18 to feel a noticable difference?
    I'm new to MTB as well as SS and want to concentrate on learning how to ride in general on the trails, and the 32:16 is just slightly too tough at the end of the climbs. (Close but not quite. I'll change back later.) I have horizontal dropouts on my SASS so chain tension is not an issue.
    Not a regular
    Quote Originally Posted by SOLO_ONE
    Very much noticeable. If a 32:16 is just too much, I think you will like the 32:17 a lot. No sense killing yourself.
    Cold. Blue. Steel.
    Reputation: OneGearGuy's Avatar
    agreed
    Quote Originally Posted by ssmike
    depending on the terrain where you live, 2 to 1 can be a bit tough. especially if you are just starting out on SS.
    2 to 1 is just an easy benchmark to go by when setting up your bike for something that should work well in a variety of riding conditions. don't bother tweeking your knees or back with too big of a gear. experiment and then you will know what is best for you.
    Spinning and Grinning...
    Reputation: scottms33's Avatar
    sass ?
    have any pictures of your sass ??
    Reputation: Soupboy's Avatar
    2:1 can be a bit much...
    ...I was running 32:18 on my 26" SS and just transferred all the goods to my 29er SS - approximately equivalent to 2:1 gearing on a 26" bike.
    The short steep switchbacky stuff is a real grunt. Flat and inclines where you can build mo' is fine but the deceleration and restarting can be a bear.
    Going back towards a 1.8:1 ratio by putting a 20t cog on there.
    Sean
    Professional Amateur
    Well I got it..
    Quote Originally Posted by scottms33
    Well I was able to get a Shimano SF-MX30 17T at the local Sun-and-Ski and put it on the bike but I have not ridden it yet.
    Here is a link to some pictures of my bike:SASS pictures
    (Sorry they're such low res , I'm using a digital camcorder to make the photos because it's the only digital camera I currently have.)
    formerly Giantxc
    Reputation: MrXC's Avatar
    Definitely a difference. I run 32-17 for general riding, and 32-16 for racing.
    Reputation: Cygnus's Avatar
    my SS gear ratio chart
    Here's a chart that i developed for my two SS bikes, one on road, one off road. keep in mind that tire diameter must be kept constant when making comparisons. I only included the chainrings and freewheels that i use. Being visual, this chart helps me understand the extent of differences in various setups as i experiment.
    Noticable? Yes.
    Start out with 32:17. It is a good all around gear for beginning and deciding whether to go lower or higher. After riding 32:17 for a couple of months building up your ss legs/lungs, switch to 32:16 and you'll be amazed how much faster you go, but you will need to stick with it for a couple of rides to get used to it.
    Out of Bounds
  1. Early Marzocchi versus Mag21
    By mojo in forum Vintage, Retro, Classic
    Last Post: 04-07-2004, 03:40 PM
  2. Nokians+mt bike versus rd bike with rd tires
    By Chester in forum Weight Weenies
    Last Post: 03-26-2004, 01:29 PM
  3. '03 versus '04 Shivers
    By MD Bullit in forum Downhill - Freeride
    Last Post: 02-13-2004, 08:41 PM
  4. Can I switch 32:16 to 32:17 or 18
    By wongmic75 in forum Singlespeed
    Last Post: 02-01-2004, 06:16 PM
  5. Marin mount vision versus SC blurr
    By jacques in forum Marin
    Last Post: 01-28-2004, 07:14 PM
