29er inverted stems- Mtbr.com
Results 1 to 17 of 17
    Over the bars...
    Reputation: egggman's Avatar
    29er inverted stems
    New bike all tricked out with a basic 5 degree inverted stem still sits just off level handlebar high. I prefer my bars slightly below my saddle. Does anyone have a recommendation for a 15 or so degree stem I can invert to get the bars below the saddle? I would prefer if it did not break the bank for now but will hold up to abuse well. Thanks in advance.
    Did I catch a niner+?
    I just flipped a Mary to give kind of the same effect. You could look at Easton stems most of them I have seen are reversible.
    A quick search:
    https://www.jensonusa.com/store/prod...sion+Stem.aspx
    May 2005
    All stems are "reversible". Unless it bugs you to see an upside down logo (like on my Thomson). For a good not too expensive stem, I'd recommend Salsa SUL stems or Ritchey Comp stems. Both are good for the money.
    (This is the perfect opportunity to use a little trigonometry and algebra to determine what length and angle stem will put the bars where you want them. Not everything they taught you in high school was a waste of time!)
    Over the bars...
    Thanks, my issue is trying to figure out who has a decent 15 degree or so stem. Most seem to only come in 5-6 degree up/down. The ritchie's look like a good fit if only I could figure out how to read the descriptions on jensonusa. More research to do... Alrerady measured out to need a 100mm stem now just to play with angles. Maybe a 105 with 15 would work....
    Reputation: serious's Avatar
    Jan 2005
    Hey egggman,
    I use a Bontrager X Light stem (100mm 17 deg, inverted) on my 29 singlespeed to get the bar level with the saddle. I am 5'6" so a 29er front end is very high for me. I bought it at the Trek Store (just south of Younge and Eglington). I think it was around $90, so not very cheap, but light and strong. You might be able to find it on-line cheaper.
    My rides:
    Lynskey Ti Pro29 SS
    RM Suzi Q 90 RSL
    KHS Team 29
    S-Works Roubaix
    KHS CX 550 cyclocross
    Over the bars...
    Thanks, I will look into that one. I am also 5'6" and on an 18" the bars are just a hair high.
    Have you already lowered the stem with the spacers? If not you can get 10-20 mm lower depending on how your steer tube is cut.
    Reputation: mitzikatzi's Avatar
    Over the bars...
    Yup, have already got the stem sitting below the spacers. Thanks.
    i don't give a shift
    Reputation: collideous's Avatar
    I use a Thomson X2 with -17 degrees.
    Over the bars...
    Looks perfect. I will be popping by my LBS and looking at available 17degree stems. Thanks guys.
    Over the bars...
    Quote Originally Posted by serious
    Hey egggman,
    Just looked at your bike pix and quoted my buddies shop. He can only get the Thompson and it looks sweet too. Ordered it up. Just think I am going to be more comfortable that way.
    the test dummy
    Reputation: insanitylevel9's Avatar
    both those bikes are awesome
    Quote Originally Posted by craftworks750
    Riding a mtb is like a reset button, 10 mins in and there is nothing else in the world that matters.
    my bikes
    Ben
    Over the bars...
    Thanks again, went in to pickup the X2 but it still did not quite get me to where I needed to be. Buddy set me up with this 35 degree drop which did it. May look a little odd but felt great in the 8-hour yesterday.
    Bar ends give the illusion that the bars are still above the saddle but measures aboud 1/2 inch below. Here is the complete toy as she sits for now...
    I think you would be a good candidate for a non suspension specific frame and fork.
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    Reputation: AndrewTO's Avatar
    Mar 2005
    Quote Originally Posted by Manicmtbr
    I was gonna say the same thing. At first I was wondering why anyone would want to do an inverted stem until I saw the frame size. Once I saw it everything made sense.
    Only reason to run that set up, imho, is for the frame geometry, most notably affecting steering and weight bias - but hey, different strokes for different folks.
    I ..... need ..... DIRT!!!!!
    ... and cookies. :D
    Over the bars...
    I'm a short guy all length in upper body and was fitted for this bike. Feels great now. Never sure if the new/this version of fit is better or worse. I am riding faster this year, either it is me/the bike or a mix. Whatever works. My bike penny pile is empty now tho so I will be playing with this one for a while.
    This response is not to be crusty, just to give some background
