29" vs. 26" Gearing Question- Mtbr.com
    I have a question that pertains to my recent switch from a 26" wheel single speed to my new 29" bike.
    Simply put, does using the same gear ratio (in my case a 36x18) on a 26er and then using the same ratio on a 29er result in a different amount of effort required by the rider? I am going to guess that it takes more effort to move the 29er down the trail than the 26er but then again I am a mathematical dunce I really can't tell the difference between the two until the climbs
    I know this has probably been brought up before but it sure seems like the climbs are a little tougher on my 29er.
    There are three kinds of people: those of us that are good at math and those that are not.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    I push 32/20 or 32/22 up climbs.. That's hard enough for me..
    R.
    It is inevitable ...
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    here's your answer
    Quote Originally Posted by onepivot
    I it sure seems like the climbs are a little tougher on my 29er.
    http://www.sheldonbrown.com/gears/
    2-1 is a big gear on a 29" 36/20 would be similiar
    I've been inside too long.
    Reputation: shiggy's Avatar
    Dec 1998
    The gear ratio is the same but you have a bigger final gear with the 29er. If you want the same gearing effort you need it look at the "gear inches".
    My excel gearing calculator can help: http://www.mtbtires.com/tech/gear_calc.xls
    A 36 x 20 or 32 x 18 on the 29" would be about the same gearing as 36 x 18 on the 26".
    mtbtires.com
  1. Replies: 154
    Last Post: 03-10-2005, 07:49 PM
  2. Replies: 4
    Last Post: 03-07-2005, 09:09 AM
  3. Replies: 0
    Last Post: 01-06-2005, 01:17 PM
  4. Replies: 0
    Last Post: 01-06-2005, 08:44 AM
