26 tooth front cog- Mtbr.com
Results 1 to 18 of 18
    blet drive
    Reputation: JUNGLEKID5's Avatar
    26 tooth front cog
    Looking at changing up the drive train on my ss. I would like to run a smaller front cog like a 26 tooth instead of a 32. My question is what should I run for a rear? Normally run 32x17or 18 in some hilly country. Thanks for any help.
    Save a tree & wipe your butt with an owl.
    Thank your local Sierra Club.
    Reputation: coke's Avatar
    32/17=26/X. Solve for X
    blet drive
    That's what I was just thinking as well but what is x
    X is Sheldon Browns Gear Calculator....
    Sheldon Brown's Bicycle Gear Calculator
    Quote Originally Posted by JUNGLEKID5 View Post
    dude seriously??? I could help you but taking some time to understand basic algebra may be really worthwile if you can't figure that out... you shoulda learned that early in high school? not trying to be condescending but honestly educate yourself. that is not a hard problem to solve!
    https://www.khanacademy.org/math/ari...roblem-example
    Reputation: AlexCuse's Avatar
    14 would get you fairly close. Anyone make a good cog that small?
    Yeah I only carry cans cause I'm a weight weenie.
    Quote Originally Posted by AlexCuse View Post
    Endless, Chris King, sure there's more.
    blet drive
    Thanks for all the input and math class. Forgot about Sheldon Browns converter
    blet drive
    Love forum board humor🤘
    Reputation: Andy R's Avatar
    Nov 2008
    I don't think there was any humour - or were you being sarcastic?
    Jan 2009
    Basic math skills, come on.
    I think surly did a blog post about micro drivetrains and why they are a bad idea. Everything will wear out much faster. This is why the 25/9 gear on most modern bmx bikes wear out so fast.
    Reputation: economatic's Avatar
    I'm actually curious why you'd want to run such a non-standard setup. That is, unless you have some spare parts with nothing to do with them.
    Quote Originally Posted by economatic View Post
    I run a 28/19 on my bike which is comparable to a 32/22.
    *From all the stuff I had laying around after pulling the gears off my bike it was the most sensible gear. Didn't have a 32 ring or 22, 21 cogs. Had a 28T and 19T though.
    *A 'tiny' weight savings on things that are smaller, chain shorter, etc..
    *Probably the best though, for my trails; North Shore, Squamish, (Whistler and Pemberton on occasion) the additional underside clearance is always welcome and..
    *Not many people run a 28/19 so it's cool to me.
    Reputation: ancient rascal's Avatar
    Oh tell us everything. If you want it easier to climb with go with 32x22t rear cog maybe. I have a SS set up with 24x22t freewheel ... 24 divided by 22 or 1.09 to 1 ... The other SS is 32x20 currently or 1.6 to 1. Why do you want a smaller chainring in front?
    Suicide by single speed. Work in progress.
    Reputation: Cygnus's Avatar
    i'm finding your signature about trees and owls tired, illogical, and not particularly humorous.
    how about we discuss bikes, or single speed issues (land use issues aside)?
    although, a 26 tooth chainring could be good for climbing trees.
    blet drive
    It is a ring that I have laying around. I like the idea of more clerance as well and I have a 14&16 rear cog hanging out as well
    If that's the case then slap that 14 on there and get out for a ride. FYI 14 is close to the X in the equation above. You can't get a cog with a fraction of a tooth so 14 is as close a match as you will get with a 26t chaining.
  1. I really really really need a {34 tooth} 9 or 10speed front chainring
    By squareback in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-16-2014, 09:59 PM
  2. Replies: 18
    Last Post: 12-11-2012, 01:29 PM
  3. 20 Tooth Front Ring....
    By Enel in forum 29er Components
    Last Post: 09-24-2012, 11:55 AM
  4. Tooth broke off my front middle chainwheel after 6 rides!
    By Michaelmcgo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2012, 01:08 PM
  5. questions regarding swapping a 34 tooth front ring for a 32
    By bikedreamer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2012, 08:14 PM
