26" Rockhopper SS gearing for city riding- Mtbr.com
Results 1 to 3 of 3
    May 2015
    I have an old Rockhopper that I'm converting to a SS setup. I have a Truvativ X9 crankset and I'm shopping for a singlespeed chainring.
    I'd like to go with a spiderless direct mount chainring and I'm planning to buy a 36T.
    Any recommendation for a rear cog size? My last 26" SS bike was 36T - 16T and that was way too slow for cruising in the city with no hills.
    I've been trying to figure out all the gear ratio stuff...is a 12T cog too small?
    Mar 2015
    I got away with 32/14 back in the day, but the smaller the rear cog the more likely it'll skip. Granted that was before I knew how to measure the chainline accurately and I was using cheap stamped cogs, maybe with a decent cog it would be different. If you have an old derailleur you could use as a chain tensioner that might do the trick, hard part is getting enough chain wrapped around that little tiny cog.
    Aug 2010
    You may be better off with a larger chainring and cog. If you can get a crankset with a more common chainring BCD you would have better chainring options. 5-bolt 94mm BCD and 4-bolt 104mm BCD are pretty common and inexpensive.
    I have an old steel Stumpjumper that I have set up singlespeed. I use 42-16 gearing on 2.25" low knob tires. This gear ratio cruises pretty well around 14-20 mph, and starts to spin out around 23 mph.
    You may want to check out the Sheldon Brown gearing calculator. Keep in mind that 36-12 is a much bigger gear than 36-16.
    Sheldon Brown's Bicycle Gear Calculator
  1. Fremont, Newark, Union City (tri-city) Pump Tracks or Riding Areas?
    By Ken Herman in forum California - Norcal
    Last Post: 03-21-2016, 12:11 AM
  2. 26" Rockhopper SS gearing for city riding
    By thomas.oconnor19 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2015, 06:35 PM
  3. Replies: 2
    Last Post: 06-25-2014, 05:09 PM
  4. Rockhopper "80mm & 100m travel" what?
    By zephxiii in forum Specialized
    Last Post: 02-14-2013, 12:11 AM
  5. Not satisfied with "standard" gearing options
    By creyc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2012, 08:38 PM
