26"---->29" gearing question- Mtbr.com
Results 1 to 11 of 11
    L&L
    L&L is offline
    I have a 26" gearie and would like to see how fast i would travel per reveloution of the cranks on a typical 29" SS with 2:1 gearing. Taking into account my smaller wheels, what gear would be the closest approcamation to the avarage 29er SS?
    Thank you for any help.
    large member
    Reputation: mud'n'sweat's Avatar
    Feb 2006
    Are you sure you want a 2:1 on the 29er? It's going to be a bit stiffer than a 2:1 on a 26"
    L&L
    L&L is offline
    The 26" has gears, and always will. The point of this post was for someone who has not ridden a SS since his last BMX (thats me), get an idea of how fast i would travel per turn of the cranks on a 29" SS. I figured i could select a gear on my 26" just to see. I want to build up a 29er just for the fun of it.
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Add two teeth to the rear cog on the 29er.
    L&L
    L&L is offline
    So a 36:18 on a 29er is roughly = a 36:16 on a 26" ? (only in the the turn of the crank/ distance traveled aspect)
    Nat
    Nat is online now
    Quote Originally Posted by L&L
    Correct!
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    L&L
    L&L is offline
    Thank-you everyone for your quick replies.
    pvd your link is alsome...it's exactly what i was looking for.
    May 2005
    Translation
    Another easy way to translate is to take your ratio: 36/18 = 2 , then multiply by the wheel diameter x 29" = 58" gear. For a 26er 36/16 x 26= 58.5"
    Gear inches are the universal wheel size language
    L&L
    L&L is offline
    Taking a look at the spec's on my 26" gearie, the closest i can come to matching a 2:1 on a 29er is 32:14 which will have me traveling alittle faster then the 29er at 2:1, but will give me an idea if i can live with a SS as a play bike.
    bike dork
    Reputation: mtbdee's Avatar
    Jan 2005
    32:14 may be a stiff gear on a 29er, assuming you have lots of hills where you're riding. Steep stuff will be a real grunt. 4 over a 2:1 ratio is a great all around SS road bike gear (like a 40:18) I know I couldn't pull it off for long on our short steep up/down trails.
    I've run 32:15, 32:16, 32:17 and 32:18 on my 26er and 34:18, 32:18, 32:20 and 32:22on my 29er. The closest combos on the 29 to match my 26 has been acheived by adding 2 teeth in the back.
    Swap cogs and give it a whirl though, everyone is different and it could be the perfect gear for you. Let us know how it goes.
