24 hole rim, 36 hole hub, fixed gear rear HELP!- Mtbr.com
Results 1 to 7 of 7
    im messing around building a 26" townie, and i'm trying to build a rear wheel. i can lace the 24 hole rim to the 36 hole hub by skipping a hole on the hub every two spokes...BUT...do you guys think that a 24 spoke wheel will be strong enough for a rear wheel? its going to be a townie...but 24 spokes seems a bit inadequate. im only 160 lb. i dont know. what does anyone think?
    AND...what about 24 hole rim on a 32 hole hub?
    Reputation: shiggy's Avatar
    Dec 1998
    Just match the rim and hub drilling. Mixing them is not worth the effort.
    mtbtires.com
    haha...yea im leaning more and more towards that
    zvg
    zvg is offline
    Mar 2006
    spoke count
    24h rim and 32h hub is easier. 16 spokes on the drive side, 8 on the non driveside. check out www.speeddream.com. I don't know if he is still doing it, but that used to be his "thing".
    Reputation: Feldybikes's Avatar
    Quote Originally Posted by zvg
    This isn't a bad idea, but don't do it if your rim has offset spoke holes. Every other spoke to each flange will be slightly different in length, since the offset would be L R L R and the spokes would be R R L R R L, and it'll pull itself outta true pretty quickly. Not just speculating, I know this from a friend trying it.
    velocipede technician
    Reputation: hollister's Avatar
    the wheelsmith mechanics built hundred's of wheels like that with no problems.
    looking for 20-21" P team
    Welsh Dave
    The low spoke-count shouldn't be a problem in itself.
    See this article from 63XC.Com re. off-road fixing with an 18-spoke wheel...
    But it depends on what spoke pattern you can devise between the mis-matched rim and hub drillings.
    DM
