2018 SS parts swap thread.- Mtbr.com
Results 1 to 55 of 55
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Old thread is 7 years old, hard to read, and mostly out of date. Let's start fresh.
    Reputation: jmmUT's Avatar
    Have:
    21 tooth fixed disc cog 3/32 Problem Solvers brand. This turns any disc hub into a fixed gear hub!
    Surly 3/32 21 tooth SS cog
    Brand new Shimano Zee 36 tooth 104 bcd chainring
    Truvativ Roleur 5 bolt 172.5 Crankset with BB for cross/road/fixie
    Dark Cycles 104 BCD bashring silver/black with sweet old school flame cutouts
    Cheap 1/8" fixed cog
    MRP 104 Bashring silver kind of beat up but functional
    PM for pics
    Want:
    Sweet bells that go ding-ding for my bikes
    Frame Bags of different sizes
    Quality mechanical disc brake set BB7 or similar/better
    Front fork rear 135mm QR spaced non-offset
    Whatcha got?
    Reputation: msedbaue's Avatar
    Mar 2014
    Have -
    Chris King 20T Stainless Cog
    XT Crank, 180mm w/ Surly 32T Stainless Chainring
    North Shore Billet 30T x 88mm Chainring
    Want
    Rad Single Speed Jersey (Large)
    Chris King 16T Stainless Cog
    2012 Pure Fix SS
    2013 Speed Concept 1x11
    2013 Air 9 Carbon SS
    2015 FM190 Fatty
    2015 Emonda SL
    2016 Macho King
    Jan 2009
    have:
    Kore Mega handlebar 31.8mm, cut to about 725mm wide, 20mm rise, black
    want:
    130 BCD 38t chainring
    Reputation: LonelyDwarfProd.'s Avatar
    Jul 2015
    Deleted
    Jan 2009
    Have: 2015 Traitor Crusade singlespeed cyclocross bike. Bright-ass green. https://classifieds.mtbr.com/showpro...product=115944
    Might trade for a medium Karate Monkey, 2015 or newer. Frameset and/or parts.
    Jan 2009
    Nevermind, that went fast.
    Aug 2003
    Have:
    HBC ti 24t SS cog. Light wear -- ridden a few times 5+ years ago. Many years of life left.
    A couple of random wheels.
    Want:
    WTB Vigo saddles in new or very good condition.
    V-brake compatible brake levers with carbon blades.
    Contact: mike dot curiak at gmail
    Jan 2009
    Have:
    Raceface direct mount 32t round ring
    Want
    DM 34t ring to fit Raceface cinch cranks
    Have:
    31.6x367 Thomson Elite post, black, zero offset
    Have:
    - BB7 brakes with gold Avid levers
    - Various brake rotors
    - Salsa Bell Lap 2 Drop Bars, 26 mm clamp
    - 27.5x3.0 Nobby Nic, Pacestar compound. New in box.
    - On One Fleegle Pro bars, polished
    Want:
    - Carbon rigid fork - either 27.5+ with ~420 A-C and QR axle or 29+ with ~510 A-C and 110x15 axle
    - Front Road mechanical disc brake caliper OR drop bar front brake lever for V-brakes
    -29er/700c disc front wheel
    Stache 7 --- Rigid Surly 1x1 B+ --- Dirt Drop CrossCheck
    looking for a set of ss drop outs for a 2015 Intense Hard Eddie
    Apr 2017
    @FRS1661 - I have a Nashbar carbon fork that might fit your needs... 100mm, QR, 1 1/8" steerer 7.5" long, Axle to bottom of steerer measures at 475mm. Crazy light!
    I also have:
    Nashbar aluminum handlebars, not much sweep, 31.8mm dia., 720mm wide.
    Deda Zero1 Stem, forged aluminum, 31.8mm dia., 110mm long, 8deg rise/drop.
    I want:
    Pedals with clips and platforms. Whatcha got?
    -Tom
    Quote Originally Posted by IL8APEX View Post
    -Tom
    No thanks! In QR I need a shorter fork (~420mm) or a longer fork in 110x15.
    Jul 2015
    Quote Originally Posted by Frs1661 View Post
    I've got an eXotic 425mm A-C Carbon fork that will definitely fit 27.5" wheels. It came on a gravel bike I picked up that runs 27.5x47mm tires and there was a ton of clearance with that setup. I just wanted something longer. It's just collecting dust on my work bench if you're interested.
    I have a pretty much new Phil Wood Eccentric BB that I took off my ritchey. Please let me know if you would be interested in it
    Jan 2009
    Have:
    Brand new Surly Karate Monkey fork. 15x110 axle, lots of braze-ons for doodads. Never used, installed, or cut. Black.
    Edit- straight 1-1/8" steerer tube, not tapered, so you can use in in any remotely modern frame with the appropriate headset.
    Attached Thumbnails Attached Thumbnails 2018 SS parts swap thread.-screenshot_20190313-085031_gallery.jpg
    Have: Vassago Jabberwocky in really good shape, tan, version with track ends.
    Want: 29er SS wheels with 142 x 12 rear axle (or able to convert).
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    Quote Originally Posted by LonelyDwarfProd. View Post
    PM sent!
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Looking for old school xtr 970 or 980 triple crankset or arms. Let me help you clean out the parts bin.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Jan 2009
    I managed to break part of the spider off this crankset, so you can't safely use 104 BCD rings on it. However, it's a 2x crankset so the small ring holes (64BCD?) are still fine. If you want a crankset that will only be used with a tiny ring, you can have these for a nominal price. Fat bike? Cargo bike?
    No BB, 170mm arms, made for 68/73mm bottom brackets.
    Out spokin'
    Dec 1999
    Quote Originally Posted by mack_turtle View Post
    Have:
    Hey Mack, that fork has an untapered 1-1/8" steerer, right? Thx.
    =sParty
    disciplesofdirt.org
    Jan 2009
    Quote Originally Posted by Sparticus View Post
    =sParty
    Indeed, straight 1-1/8" steerer.
    Out spokin'
    Dec 1999
    Okay then, it's not for me. Thanks.
    =sParty
    disciplesofdirt.org
    Dec 2013
    Rod
    Rod is offline
    Oct 2007
    Hey Mack, I saw this and maybe you all can work out a deal.
    Needed: BMX front loading stem, 1-1/8 steerer.
    Jul 2015
    Quote Originally Posted by OneBadWagon View Post
    What size steerer clamp? I have one of these collecting dust: https://www.amazon.com/Origin8-Fix8-Stem/dp/B00T6OW94Q
    Jan 2009
    All BMX handlebars use a 22.2mm clamp.
    Jul 2015
    I know that's the traditional standard, but I've seen 25.4mm bars coming out from a few companies (We The People for example), for "adult" BMX type bikes, so I figured it couldn't hurt to ask.
    Jan 2009
    Ah, I am old and out of touch!
    Jul 2015
    I hear that. I only knew from part hunting for a bike I was working on for a friend's kid.
    Rod
    Rod is offline
    Oct 2007
    Looking for Smart trainer
    Maxxis Ikon or Ardent 2.3 or 2.4
    Whiskey or Niner tapered fork 15mm axle
    Have Stans SS hub
    Suntour Raidon fork
    Giant xc-1 wheelset
    Dec 2013
    Quote Originally Posted by Rod View Post
    Still looking for an xt 770 crankset or other 104 bcd crankset
    Smart trainer
    104 bcd chainring 32 and 34
    Have Stans SS hub
    Suntour Raidon fork
    Giant xc-1 wheelset
    Sent a PM to you.
    Deflated - buy parts to sell parts to buy more parts.. bikes are my drug of choice
    FATTrailer for the kiddo
    Nov 2013
    Have: 2 almost new Surly Knard 29 x 3.0 27tpi wirebead tires.
    Want: Rear Shimano XT hydraulic brake.
    Nov 2014
    If anyone is in the UK I have the following for the cost of postage. Don't need anything currently but hope for good karma in return 👍
    Velosolo 32T ring. Really nice quality ring and very little use
    KCNC Arrow Stem (90mm, -17, OS, little use) and Syntace F109 stem (110mm, +/-6, OS, little use)
    Blackspire Stinger, can be used as a BB tensioner. Fitted and used in the workstand only.
    2x CB cleats, new
    Shock pump. Can be sent anonymously if you don't want to reveal you haven't MTFU and run rigid on your SS
    Additions to the have list and clarification to my wants list:
    Have:
    - On One Fleegle Pro bars, polished 17* sweep, 660 wide, 25.4 clamp
    - Bontrager Riser bar 750 wide x 15 mm rise. 9 deg sweep, 31.8 clamp
    Want:
    - Carbon rigid fork with ~420 A-C and QR axle
    - Rigid fork: 29+ with ~510 A-C and 110x15 axle
    - 29er/700c disc front wheel
    Aug 2003
    I have a disc front wheel: https://bigwheeldeals.blogspot.com/2...elset-for.html
    Send me an email and let's figure something out: mike.curiak at gmail.
    Jan 2009
    I still have:
    Damaged SLX cranks (see above)
    Brand-X dropper post, 31.6mm diameter, 125mm travel, external routing. Used 4-5 rides
    Looking for:
    34t direct mount chaining for Raceface Cinch cranks
    Stealth Maxle for Rockshox 100x15 fork
    Reputation: caemis's Avatar
    Dec 2015
    Hi, I am thinking of trading my Matt Chester Utilitiman (26"/Vbrake) frameset for something more modern, i.e. 29" XC and handbuildt. Of course still for one gear Maybe someone is interested?
    Still not sure if its a good idea or I rather should wait a while and just buy another frame...
    Cheers,
    M.
    Not a Barry supporter.
    Reputation: Crash_FLMB's Avatar
    I have a WTB Rocket V in 142mm. The wrong size showed up and it's too big. In perfect condition. It was on my gravel ride. Id love to swap for exact same seat in 127mm size.
    Also looking for 5-bolt 36 or 38T chaingrind for my old school Race Face cranks on the gravel but I know those are rare.
    Sent from my LM-G710VM using Tapatalk
    Why would I need more than one gear?
    @A_SingleSpeeder
    EPA = crooks!
    Quote Originally Posted by caemis View Post
    Cheers,
    M.
    I looked at trading in/selling my cherry Utilitiman but there's not much money in it at this point. I ended up putting flat pedals on it for tooling around town.
    Reputation: AlexCuse's Avatar
    have: DT swiss 240 bolt on SS hub, matching front in RWS configuration. both 32 spoke centerlock and very convertible.
    want: some kind of boost SS specific hub
    30.9 dropper post?
    Yeah I only carry cans cause I'm a weight weenie.
    I have a ritchey WCS full carbon 29er fork with 7 1/4" steerer remaining also
    Jan 2009
    Quote Originally Posted by AlexCuse View Post
    What are you looking to trade for it?
    Sorry meant as an addition to post above. Complete list:
    have:
    -DT swiss 240 bolt on SS hub, matching front in RWS configuration. both 32 spoke centerlock and very convertible.
    -Ritchey WCS full carbon 29er fork with 7 1/4" steerer
    want:
    -some kind of boost SS specific hub
    --maybe a nice high engagement geared boost hub
    -30.9 dropper post?
    Reputation: jake2185's Avatar
    May 2010
    Have:
    SS specific, Bontrager RXL scandium rear wheel w/ Bontrager branded DT Swiss 240 hub, 135QR, white spokes. 29”. Can be converted to 142 with the DT axle kit. Excellent condition.
    Niner RDO stem, moondust color, 90mm. Nice.
    A few QR wheelsets. WTB Laserdisc 29s and Bontrager SSR with Deore hubs.
    29” Bontrager race TLR front wheel QR
    Roval Control AL 29” rear wheel. 142. Specialized hub
    Extra-lite Brake set. No pads or pad holders though.
    Avid Speed Dial Ti V-brake lever set.
    Want:
    29” XC tire pairs, 2.25-2.4”. Schwalbe, Maxxis.
    Crank bros Egg beaters or Candy’s
    Specialized Phenom saddles
    160 rotor pair
    Willing to entertain any other trade offers.
    Jake dot broadway at gmail
    My bikes are faster than me.
    Downcountry AF
    Oct 2013
    Have: Hope Pro4 135mm bolt-on SS/trials rear hub, Blue, 32h, 88 POE, excellent condition, original box included. Used one season on a cross bike.
    Want: bike stuff. 180 cranks, high engagement hubs, King headset?, XL frames.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Have:
    - ENO crankset square taper, Silver 175mm arms, Couple chainrings - probably one that works for you
    - DT Swiss 240 bolt on singlespeed hub 32 hole centerlock (can be converted to 142mm)
    Want:
    - Boost singlespeed specific hub (may be open to a high quality geared hub, strongly prefer centerlock and 32h)
    - One of those nice dropper remotes that looks like a shifter - something that works with a KS eThirty post
    - 170mm boost carbon cranks
    more details please
    Jan 2009
    Quote Originally Posted by bnelson View Post
    more details please
    More specific please. Details concerning what?
    still have pw eccentric bb
    Jul 2015
    Updated
    Have:
    -Kenda 700c x 45mm Bitumen Tires w/ Reflective Sidewalls (Ridden Once)
    -Older Time Pedals and Cleats (Not Sure of the Model)
    -Avid BB5 Calipers w/ Pads
    -185mm Avid Rotors
    -Microshift 10-Speed Shimano MTB Bar End Shifter (installed once but decided to keep the bike singlespeed instead)
    -Marin "Urban" Cro-Mo fork, ~468 A-C, IS Disc Brake
    Looking For:
    -27.2 Layback Seatposts
    -650b or 700c Gravel Tires
    -29+ Tires
    -Single Speed Road Levers (with brown, gum, or tan hoods)
    -36T 104 BCD Narrow Wide Chainrings
    -700c/29er or 650b Wheelsets
    I have a Surly ECR fork I've been thinking of replacing with some carbon disk ready fork. It's non-tapered and steerer is cut to about 7.5". If that sounds like something that would work for you, let me know. I can always use more Times and the Kenda's would probably help me out also.
    @A_SingleSpeeder
    EPA = crooks!
    Jan 2009
    Soma fans: I got this Soma cap a few years ago. It doesn't fit the shape of my head well and I don't own the 2 (two) Soma bicycles anymore. I have no idea what this is worth in a trade. Another hat, weird size medium jersey, some grips, fresh bar tape, etc.
    Jul 2015
    Quote Originally Posted by Crash_FLMB View Post
    Totally missed this reply to my post. Sorry! I got a fork for my birthday, so I'm set there, but I'm still willing to trade the tires and/or pedals depending on what else you've got. Let me know!
  1. SS Parts Swap Thread
    By damnilocano in forum Singlespeed
    Last Post: 04-29-2018, 08:17 PM
  2. Replies: 8
    Last Post: 01-24-2017, 01:57 PM
  3. DJ Parts Swap Thread
    By sasquatch rides a SS in forum Urban/DJ/Park
    Last Post: 03-13-2014, 01:34 PM
  4. Replies: 442
    Last Post: 01-09-2012, 10:40 AM
  5. Parts Swap Thread
    By BKruahnndon in forum Lights DIY - Do It Yourself
    Last Post: 10-02-2011, 09:12 AM
Members who have read this thread: 156
