2010 Gary Fisher RIG SS owners?- Mtbr.com
Results 1 to 6 of 6
    I ride with tools
    Reputation: Jim Beam's Avatar
    What rear brake are you running?
    I ask because.... I had a 2008 and somehow bent the rear triangle. Trek sent me out a new 2010 (very purty BTW), but when I built it up and rode it, the rear brake is howling like a banshee and setting up a wicked vibration through the whole bike. Bad enough to make me want to pitch the b!tch in a dumpster.
    Rotor bolts tight? Check
    Adaptor and all other bolts tight? Check
    Pads clean? Check (tried both new metallic and new organic and no help there)
    Rotor clean? Check
    I'm out of ideas and have garaged the bike because it is NO fun to ride. Hoping some other 2010 Rig SS owners can chime in.
    (edit) should have mentioned - brakes are Juicy 7's which were quiet on the '08 Rig
    thx
    What brakes are you using? Switching from Hydraulics to some BB-7's might help.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I run a BB 7 , I would say that the setup of yours may be the problem . Recentering the caliper and chamfering the pads may help .
    SBT
    SBT is offline
    Reputation: SBT's Avatar
    http://forums.mtbr.com/showthread.php?t=425196
    I installed a set of Elixirs on my Rig, and am experiencing a similar phenomenon.
    I'm sure it's mentioned throughout the thread, but on the last page, Pedalphile mentions filing down uneven edges in the rotor vents.
    I'm going to try this.
    Never Satisfied...
    Jan 2009
    bb7
    openwound
    Reputation: voodoochild's Avatar
    Face the brake mount?
