2 x 1 ?- Mtbr.com
Results 1 to 13 of 13
Thread: 2 x 1 ?
    Mar 2006
    New question here. 2 x 1 ?
    Is it possible to run a single rear sprocket with two chain rings and a bashgaurd?. Will a chain tensioner take up enough slack to get rid of the RD, cassette, and rear shifter while keeping the FD and two chain rings with bashgaurd. This is for a freind who rarely shifts and constantly wrecks his RD, but would like to keep the two front gears for climbing vs flat trail.
    don't sweat the petty things, and pet the sweaty things
    Out spokin'
    Dec 1999
    No. In order to take up that much slack your friend would need to keep the rear derailleur or run a Paul Melvin tensioner (which is as bulky as a RD). Might as well keep the RD.
    Paul Melvin tensioner:
    --Sparty
    disciplesofdirt.org
    one chain loop
    Reputation: fishcreek's Avatar
    +1 to Saprty.
    keep the RD. put the chain on the larger chainring and remove excess chain, i mean to the point that the RD is almost horizontal. dont worry, you are not gonna break your RD spring.
    i will go for 1x2 though, throw your FD away.
    everything sucks but my vacuum cleaner.
    Mar 2006
    Paul Melvin tensioner seems like it would do the trick to run a 2x1. But how exactly could you run a 1x2? Run two separate SS rear sprockets with spacers and just leave the RD.
    Out spokin'
    Dec 1999
    Quote Originally Posted by rekibtm
    Yes. Fishcreek's got the right idea. Surly's SS cogs have wide bases. If you stack them together you wind up with standard 9-speed spacing. You could use 2 or 3 or...
    Then ditch that chain sucking FD altogether.
    --Sparty
    disciplesofdirt.org
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    I have that setup on my beater bike and it works great. I use an old derailler rather than a tensioner though. It's cheap, readily available, and takes up a lot of chain slack just like it's supposed to.
    Exclusively Single
    Reputation: long hazy daze's Avatar
    One ring, one cog. Walk it if you can't ride it. This is the only real solution.
    However, If one must run some gears, for the love of fair trade coffee, run a RD or better yet, a geared hub. I hate FD's more than life itself; worst bike component ever invented.
    one chain loop
    i agree, worst component ever; next to bike horns.
    Exclusively Single
    Quote Originally Posted by fishcreek
    Whoa. You just crossed the line. Take that back, immediately if not sooner.
    one chain loop
    i'm sorry i can't. i just can't imagine myself taking my hands off the handlebars and squeeze those that resemble a breast pump. lol
    Hud
    Hud is offline
    Singletrack minded
    Reputation: Hud's Avatar
    What about a surly dingle rear cog? Thats a 2in1.
    "Ride Lots" Eddy Merckx
    Reputation: kkjellquist's Avatar
    Just curious how your friend is wrecking multiple rear derailleurs? Crashing?
    "Big Gulps huh?...Allllriggghhht....Welp, See ya later!"
    Mar 2006
    Quote Originally Posted by kkjellquist
    yeah crashing, landing jumps wrong, hitting trees. Our local trail is really tight twisty single track "with a catastrophe waiting around every corner". We ride there enough to go faster than you should. My buddy can bunny hop, leap off and over anything. And on tight single track it always doesn't work out. He has probably destroyed 3-4 RD in the last few years. He only uses about two gears usually and has been interested in a SS for a while now. Right now he rides a DJ bike wich is the best thing for his style of riding..
