1x9 questions (blasphemy I know)- Mtbr.com
Results 1 to 7 of 7
    I'm working on a 1x9 racer for longer (12 hr) events. I have been contemplating my choices for keeping the chain on the chainring. The best solution I have seen was on a KM 1x9 that used a chain guide to keep the chain on. They ran an XTR crank with Jericho ring (ring any bells?).
    I'll be running an XTR crank with a new spider and most likely a bashring. I am about 220# and concerned with reliability not weight, as I break too much stuff to worry about a few ounces.
    Or I can use a Jump Stop with a bash ring and hope that will keep the chain on. The chain would have to jump pretty high to fall off.
    What do you think? and any recomendation for a chain guide?
    Thanks in advance, and I appologize for the geared content but this board IMHO has a great amount of bike wisdom to share.
    Winky
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    Quote Originally Posted by Winky
    i have had good luck with that setup. it is cheap and easy, like me.
    i've launched some good sized stairways and ridden some pretty rocky trails without dropping chains.
    Reputation: Zenfrog's Avatar
    mrp
    I run a MRP on my Chameleon 1 x 9. A little too heavy but works really well. If i was going to do it again I would do 1 x 8 so it doesnt cross chain so much.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    I am running 1x9 on my softail....
    I have my Dean Duke set up 1x9. I am also using XTR cranks with a AC spider and a Spot guard and N-gear Jumpstop. It's a great set up and I don't think I'll be dropping any more chains.
    Tips;
    1. Get a nice SS rings, like a Spot or Salsa. The teeth will have more profile, there will be a less likely chance of droppping a chain and you'll get longer wear.
    2. Try to get your chain as short as you can...you get crisper shifts and less chainslap.
    I just washed my bike after yesterday's ride, so here's a pic for ya...
    <img src=http://gallery.consumerreview.com/webcrossing/images/lores1x9(2).jpg>
    Cheers!
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    Winky
    Bingo! That's what I use, and I weigh the same as you. I ran that combo for a12 hr race and few trail rides like that last season with out a wimper. It's cheaper than anything else out there too.
    Just a regular guy.
    i likee
    no need for the chain guide hun? That saves a lot of weight. When i put my mrp back on my Giant I might have to go for something like that. I thought I would go for a lighter chainguide but if you guys say this works....
    Ride More
    Winky
    I had the same question. check out this link
    http://forums.mtbr.com/showthread.ph...&highlight=1x9
    What worked for me was the Rohloff chainguide. You can get from Bill Larson for 40 bucks.
  1. All Ultimate questions answered here.....
    By 2melow in forum Tooltime
    Last Post: 02-16-2004, 10:34 PM
  2. picked up an sgs pro today... got some questions:
    By butocabra in forum Downhill - Freeride
    Last Post: 02-02-2004, 09:49 AM
  3. Newbie SS'er has two questions....
    By []D[][]v[][]D in forum Singlespeed
    Last Post: 01-26-2004, 01:22 PM
  4. Fork Oil Questions
    By Zizzle to the Tizzle in forum Shocks and Suspension
    Last Post: 01-22-2004, 11:46 AM
  5. Replies: 8
    Last Post: 01-20-2004, 03:20 PM
