16 tooth rear sprocket- Mtbr.com
Results 1 to 8 of 8
    Mar 2016
    I have been riding a 32X17 combination, Im looking to increase some local course times and a little speed, so checking to see if anybody knows were I can pick up a lightweight 16 tooth rear sprocket!
    Reputation: AlexCuse's Avatar
    Yeah I only carry cans cause I'm a weight weenie.
    Reputation: A1an's Avatar
    Endless as well if you want alloy.
    Signature
    Aug 2014
    Bunch of great options here in every price range. Endless is a great choice though.
    https://www.google.com/search?q=16t+...umDA4Q_AUIBSgB
    '15 Niner Jet 9 Carbon
    '19 Karate Monkey
    Motobecane Boris
    Raleigh Willard 3, Furley & Militis 3 (SS)
    Nashbar Carbon Road
    more skier than biker
    Nov 2006
    I would just walk into my local bike shop and buy one from them.
    Jun 2010
    Dont bother with aluminium cogs. Wear out way too fast. Pick up a Chris King stainless. I've found they last the longest.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Kings are my go to cogs also.
    OP may want to consider going to 34t up front. I run 36x18 or 17 most of the time nowadays where my buddies tend to run 32/33/34x18.
    For trail riding (I don't typically do every possible log roll of epic proportion) a larger chainring is preferable for more of a direct drive feel as opposed to getting below ~17 teeth on the rear cog. Smaller cogs tend to feel a bit more sloppy through chain slack when torquing on the pedals..
    from BikeCalc.com - Fixed Gear Calculator
    【ツ】 eDub 【ツ】
    Speaking of cogs and gearing, my spec crave has 32-20 gearing = ratio 1.6/1, which I am OK with. The RSD Sergeant which I'm thinking about, and converting to SS, comes with a 30 chain ring. So I would probably put a 18T to give me ratio of 1.67/1. Are there any advantages to having a bigger chain ring though fairly equal ratios?
    The crave is fun but the chisel rigid fork is hard on the body, so looking around. I'm a mid phat tire fan and want on my ss.
  1. One Up 45 tooth sprocket??
    By kingchickenstrip in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2016, 06:51 PM
  2. 36 tooth to 32 tooth sprocket
    By mcbike420 in forum Downhill - Freeride
    Last Post: 10-19-2015, 07:54 PM
  3. Setup prob with Hope 40 tooth sprocket (XX rear derailleur), please help.
    By <Steven> in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-13-2015, 09:35 PM
  4. One Up 42 tooth cassette sprocket
    By rlewis in forum Fat bikes
    Last Post: 12-02-2014, 01:06 PM
  5. 38 tooth rear sprocket feed back required ?
    By fat arse racing in forum General Discussion
    Last Post: 04-16-2013, 11:10 AM
