130 BCD Cranks- Mtbr.com
Results 1 to 6 of 6
Thread: 130 BCD Cranks
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    130 BCD Cranks
    hey guys, I was about to bid on an Item, I need to now what is the smallest sized ring that will fit on a 130 BCD crank that you can buy easily(sorry ISAR I dont have to money for a bling ring).
    P.S. An SS ring
    "If women don't find handsome , they should at least find you handy."-Red Green
    39 is common, 38's are out there.
    http://sheldonbrown.com/harris/chainrings/130.html
    one chain loop
    Reputation: fishcreek's Avatar
    road cranks on mtb frame?
    everything sucks but my vacuum cleaner.
    I'm planning to put an Isis, compact road crank on mine next week. With 110 Bcd compact road cranks 34t rings are common and road cranks have much lower Q factors. I'd like to use a Sram Rival road crank but have a 73mm bb shell and don't think it would work.
    2 wheels
    Reputation: scooter916's Avatar
    smallest ring on 130BCD is 38t, Salsa makes a great ring, about the same price as a Homebrewed ring tho. if your using a road crank you will most likely need a three piece set with a wider MTB BB most external BB road cranks won't clear MTB chain stays
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    ruppsters link had a very fairly priced ring , the ring didnt seem too bad and its great that you can run both 110 bcd and 130 bcd cranks with the same ring
