12mm bolt through single speed hub- Mtbr.com
Results 1 to 8 of 8
    Hi guys,
    I'm looking for a 12mm bolt through rear hub for a new build I'm putting together.
    Obviously I want a single speed specific hub, but I need it to be 12mm bolt through rather then 10mm bolt up like hope of Chris king.
    Budget is not an issue, but I can not find one, does anyone have any suggestions?
    Thanks in advance
    Ian
    Reputation: Kanza's Avatar
    I think you can spec the Hope Pro range this way? Check out their website for details of options, I'm pretty sure you can and it is a very good hub!
    -k
    I rang hope up, they don't spec a 12mm axle for the hub, they can convert to 9mm qr but not 12mm.
    But they are excellent hubs been running hopes since their bulb days!
    I rang hope up before posting this thread to ask if they were compatible. And because of the different free hub you can not fit the 12mm axle to the hope ss hub.
    OK cool. Good to know!
    Cheers, K
    No worries. I've asked philwoods if they can make some hubs up for it
    Did I catch a niner+?
    Hadley SS hub can be converted to 12mm.
