I have a Ti SS 29er and get slight tire rub when really pulling hard on steep climb. I wanted to try a 10mm before I pull the tire further back into the stays. The rear tire is a 2.4MK on Archs for reference.
Will a 10mm thru bolt help stiffen up the rear a tad??
I have some i9s and they have a 10mm conversion kit for them but I do not want to shell out $$ for something that will not help.
Does anyone run a 10mm thru bolt on their SS rig?? Front or Rear?
