1/8 inch vs 3/32 Compatibility?- Mtbr.com
Results 1 to 3 of 3
    Jackbooted Elitist Hipstr
    Reputation: Singletrack Pig's Avatar
    I just took delivery of some sweet Middleburn cranks with the single ring in the front. I went to put the chain on the ring and it didn't fit. Turns out the ring is 1/8 inch.
    Can I run a 1/8" ring and chain with a 3/32" Endless cog in the back?
    Dirtbag since '89
    FTM
    FTM is offline
    Reputation: FTM's Avatar
    Sep 2004
    Quote Originally Posted by Singletrack Pig
    yes you can.
    Reputation: tidelag's Avatar
    No Problemo. Maybe a little more noise from the cog?
    The 1/8 chain are wider than 3/32, so you cannot use 3/32 chain because your chainring
    is 1/8 wide. FYI.
