1/8" chain with 3/32 rings- Mtbr.com
Results 1 to 5 of 5
    Single Speed Steve
    Jun 2005
    Has anyone noticed more chain noise when running an 1/8th" chain on 3/32 rings vs. 3/32 all around? I've looked very closely and can see a little space between the ring and inner chain plates. Not sure if this would create extra noise or not. I am religious about lubing the chain so that should not be a factor.
    Mar 2005
    Not any more noise
    Quote Originally Posted by ssoulrider
    I don't think you should notice anymore noise as long as you have good chain tension. If you have a spot or similiar chain/bash guard with a 3/32 chain ring you should probably run a 3/32 chain, cause you might get a little bit of rub on the guard, that's what I do on one of my bikes, the other one is running a 1/8 chain on a bmx integrated ring guard, 1/8 size and a regular fw which can run a 1/8 or 3/32 chain, i've not noticed any bad annoying noises.
    Single Speed Steve
    Jun 2005
    I am currently running the Sram PC-1 but will switch to the PC-58/68. I saw another post that said the PC-1 is a low budget chain. I have noticed it does have a tight spot in it. I get it clean and well lubed. Thanks for replying, no one else did.
    Quote Originally Posted by single1x1
    Cubicle Fugitive
    Reputation: czardonic's Avatar
    Low budget!
    The PC-1 is a great chain at a great price. A strong, nickle plated chain for under $10? That beats the PC-58 hands down.
    Reputation: Sideways's Avatar
    Feb 2005
    One runs the risk of breaking the chain when it doesn't fit right.
    -Marshall Hance
    EndlessBikeCo.
  1. popped a chain link -- time to replace chain??
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2005, 03:27 PM
  2. Should I shorten my chain?
    By Vulcan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2005, 09:20 PM
  3. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  4. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  5. Noisy chain when in middle ring- HELP!!!!!!!
    By HPilot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-01-2005, 10:49 AM
