I just purchased a new Trek Stache, and the LBS has a special going, where all accessories are 20% off on initial order. I know that I need to buy a good air pump, pedals, helmet, bottle cages, and gloves, but what other things should i consider?
Then go riding. Ride with more experienced riders and see what gear they use. You'll have plenty of time to decide what you want/need/use or won't use or don't need. If you try to get it all up-front, you're likely to end up with stuff you don't use.
Small first aid kit to put in your pack if you use one. Cleaner/greaser is needed eventually but not until you've got a few miles on the bike or you get it pretty dirty. A new bike should come all lubed up and ready to go. I've found most car/motorcycle lubes and cleaners work with bikes so I don't bother buying separate stuff.
Buy spare inner-tubes or the equipment to go tubeless. Ghetto tubeless with Stans should only cost you ~$50.
See if your LBS can order you a few extra rear derailleur hangers to keep in your pack as well. Bending your rear hanger doesn't happen often, but you don't want to be deep into your ride when it happens. Also, a few extra tubes.
What u need partially depends on how far u ride from trail head/length of rides.
Primary is a decent helmet. Dont cheap out!!! Get one that fits properly.
Stock pedals are usually crap but they'll last u a little while till u decide on better.
Padded shorts is a good idea if u plan on riding more than about 30mins at a shot.
Normal floor pump honestly dont need to spend crazy money on, ffs I've used a $25 schwinn pump for the last 2 yrs works just fine.
Multitool is a good idea for quick trailside repairs. If u get a decent one (I swear by my crank brothers m19) it'll cover most tools ull need for at home maintenance as well. But get one with a chain breaker and see if u can get quick links (kmc missing links for example) from lbs.
Bottle cage, really only need one, if ur going in long rides a hydration pack is a much better investment.
Spare tube/patch kit not a bad idea. The slime "scabs" are great for trail side.
Sent from my Nokia Stupid Phone using Tapatalk
What hasn't been mentioned is co2 and head for inflating a flat after u patch or replace the tube. At first I bought a little pump that attached to the frame. Yah, don't do that. Co2 is the way to go -- just get a head that supports presta and schraeder valves.
Unless ur trek dealer sucks and keeps them all treks are supposed to include shock pumps when bike has air forks/rear shock. They literally come in the box with the partially assembled bike when its ordered in to the lbs. So if lbs didn't give it they are hording to sell at retail.
Sorry hopefully saving op from spending un needed money. My Trek dealer told me about this when I was ordering a shock pump for my new forks. One of the listings was the same one they include with new bikes.
I only seen lights mentioned once above. So I will say it again! Get some lights!! My girlfriend and I really enjoy our late night neighborhood rides. If you can't make it to the trail, night time city rides are the next best thing!
Also a good bike rack for getting your bike to the trails!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
