I have a 2007 Specialized rock hopper FSR. I am in my first year riding and have ridden the crap out of it this season. It is mostly cross country with a little downhill.
Now after a season of riding I want an upgrade.
My bike was nearly new when I bought it(never used by the previous owner. The only thing it did not have is disc brakes. If I upgrade to them including wheels it would be about $600 cdn. I figure I can sell it for as is for about $400-450 which take me to the $1k range For another $500-$1000 I was thinking I could get a new bike. I was looking in the $1500-200 range
The problem is I am not sure that will get me much more than I have other than new.
My option is to ride it another year and take a big leap to the over $3-4K range.
If you are willing to try and buy used $1000 will take you a long way. I've bought a Santa Cruz Superlight (full suspension) with full XT for $700 on pinkbike.com. Check out their buy and sell section.
Well, in the end of the say it all comes down to your budget and how comfortable you are with spending that money now. I would personally wait 1 more year if I were you and buy a new $3-4k bike.
You could buy new XT hub and brakes for well under 600. Depends on how much you like the bike. I built up a 2006 trek liquid and love it, and it only cost me a few hundred buying stuff I found cheap on ebay here and there. I had another bike so it wasn't a big deal to do a slow budget build.
If you think that there is a chance you are going to want to upgrade more than just the brakes (which I would say there is since you mention leaping to a $3-4K bike), don't bother. The most expensive way to get a great bike is to start with a cheap bike and upgrade everything.
If that means "suffering" with v-brakes for a year, it is really not that big of a deal IMO. There are several things you can do to get more out of the v-brakes you already have that are cheap and will make big performance improvements.
1-Get good brake pads, something like Kool Stop. The pads that come with low end v's are usually crap, and the biggest difference (performance-wise) between low end v-brake calipers and high end ones are the pads. $20-30 should take care of front and back.
2-Cables. Something like Jagwire Ripcords make a huge difference over stock cable/housing in my experience. Much less flex in the system for a more solid feel and more power going to the calipers instead of flexing the cable housing. Ripcords run around $25-30 if you look around.
So that is ~$50-60 to hold you over until you can afford a higher end bike.
Also, if you find that you are getting much flex at the brake bosses (they get pushed apart when you use the brakes) then a v-brake booster can help in some cases. On more flexy brake bosses they make a huge difference, on stiffer ones not much. Some frames and forks they have done wonders for me, others I did not even notice a difference. You can find one for ~$10 and try it front and back to see if it makes a difference.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
