Frame Size & Color: Large / ano black
Rear Shock: RS Monarch Plus
Fork: RS Revelation Black Box / tapered steerer / 20mm thru axle
Brakes: Avid XX WC / 180mm F / 160mm R
Shifter: Sram XO 10spd
Cranks: Truvativ Stylo OCT 175mm
Chainguide: e13 TRS+
Rear Derailleur: Sram XX med cage 10spd
Pedals: Deity Decoy 2.5 / flats for life
Stem: Truvativ AKA 60mm
Handlebar: Deity Black Label
Seatpost: RS Reverb
Saddle: SDG Formula FXR / Ti rails
Bottom Bracket: Truvativ
Chainring: e13 Guide Ring / 34t / black
Chain: Sram PC1091R
Cassette: Sram PG1070 / 10spd
Headset: Cane Creek 40 / 0 stack 1-1/8" top / EC 1.5" bottom
Grips: ODI Rogue
Tires: Michelin Wild Rac'r 2.25
Wheels: Sun Ringle Blag Flag Pro
Weight: ? / Doesn't matter if it feels balanced and fast.
Since I took the photo I swapped out the saddle for a new SDG joint that's not out quite yet and the new SDG/ODI lock-on grips.
Rider
Weight: 175lbs
Height: 5'11"
Seatpost: RS Reverb
Chain: Sram PC1091R
Grips: ODI Rogue
Rider
Weight: 175lbs
Height: 5'11"
