I'm looking to convert my 26" hardtail (v-brakes) into basically a hybrid type bike mainy for road use. Right now it has a 5" travel suspension fork, would putting a 100mm travel corrected rigid fork (like the surly instigator) drop the frame too low in front? What about an 80mm like the surly 1x1? Are there any other fork options I should consider in the price range around $100?
I've tried the Instigator on some bikes (Rockhoppers) designed for 100mm forks, and I find it too small even on those. I've liked the Instigator best on a Giant STP frame designed around an 80mm fork.
What model/year is your hardtail?
There weren't many v-brake hardtails designed for 5-inch travel forks (more likely 80-100mm), and for road use, you probably don't want a really slack headtube angle.
OP, any hardtail with a 130mm fork will have a slack HT angle and a high BB. Since you plan on using it as a "hybrid" it is not going to hurt to run a shorter fork that steepens the HT angle and lowers the BB. I like the Kona P2 440mm fork
There are two versions of it. One is disc brakes only, the other's with both options. It even comes with adjustable vbrake mounts for both 26er & 29er. http://www.voodoocycles.net/components.htm
This seems like a great option, I will go with this. Thanks for the replies everyone
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
