So just got a new wheel set WTB Laser Disk Trail with DT Swiss 370 hubs and first day out I hit a hiding stump and destroyed my front wheel:madman: They were nice and stiff wheels they felt great but I hit the stump hard no wheel could have held up luckily I did not get hurt. So my question is is it hard to lace up a wheel I have seen videos online I just want to get it close so that the guy at the shop can finish it up. I can save some cash if I get it close anything I need to know?
Did your mechanic tell you he'd finish a wheel you started? They won't always...
Lacing a wheel is not hard. You just need to be patient and follow instructions. I use the instructions on sheldonbrown.com. Another poster here, Mike T., has a web page devoted to helping people build their first wheels.
It is time consuming, though, and a mistake can screw up your finished product. So take your time, follow instructions, and put it down for a while if you start getting impatient.
Its not the lacing thats the issue, its getting the spoke tension correct.
Spoke tension is the key to a strong wheel and very tricky without lots of experience and even a spoke tension gauge.
Maybe you could lace the wheel and get the LBS to finish tensioning it?
Personally i would not ride on a wheel that has not been spoke tensioned correctly by an experienced builder
If I were building your wheel for you, I would not appreciate you starting it. Everyone who builds wheels probably has their own little things they do. I thread all the nipples down to the last thread showing and increase tension gradually and evenly from there. Your wheel builder likely has their own way of doing things and it would throw them off to pick up a half laced wheel. I would bite the bullet and either build it yourself or give it up whole to the mechanic.
That, along with patience and discipline will give you good odds for success. It takes a fair amount of time for me to build a wheel usually about 3 hours+/- by the time it's all done), but it's very satisfying to build and ride your own wheels.
I do recommend quality parts like DT Swiss, Wheelsmith or Sapim spokes and I would go with brass nipples for your first few builds.
Making your own 'tool' from a #2 phllips screwdriver will also help a lot.
All of my spokes are still good do i need new nipples? I have no problem trying to build the wheel and I am sure I can do it its just the final tension I am not sure exactly where it should be. For example my fulcrum rm5s with flat spokes are much tighter than this wheel set with round spokes.
Assuming you're using the same model rim and hub, it should be OK to use the spokes again IF they didn't get stretched beyond the point of being able to return to their original length. If your wheel got righteously taco'd, some of the spokes may be damaged.
You can get silver double butted Sapim spokes here for $0.40 each:
They will send a set of 14g x 14mm nipples (they don't have 12mm nipples) so just toss 'em and use 12g x 12mm like your wheel came with.
I'd get new (clean) nipples for sure so it's easier to get them up to tension with little or no twist.
Use the existing rear wheel as a template for tension. I'd likely go a little tighter and remember that the non-drive side will have less tension than the drive side (just dish it correctly and that will take care of itself), so remember which side you're trying to emulate.
If you're going to attempt this, make sure you do as much reading as you possibly can before you start. Know the process like the back of your hand, know why you do each step and what each step does before you even unlace the old wheel. Taping the new rim to the old rim and transferring the spokes one by one will keep you from needing to learn the lacing pattern. And never assemble a spoke without some sort of spoke prep or at least locktite.
Do everything slowly, rushing a wheel build is the best way to ruin a wheel build. I won't say you can't do a wheel build (you certainly can if I learned) but make sure you are prepared and willing to do things properly and carefully. A truing stand is almost indispensable, and you can get away with dishing the wheel in your frame.
Front wheels are not that hard. Even with disc brakes, they're not as dished as a rear wheel, which is the thing that makes them tricky.
Just take it slow. Give yourself permission to pick it up and put it down a few days - just don't stop mid-step.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
