what do you think about this hardtail bike.
Frame AltairX Custom Butted-Aluminum Trail-Tuned POWER STAY frame, reinforced-gussetted downtube, sculpted rear dropouts with replaceable rear derailleur hanger, H2O boss, International Standard rear disc mounts. Rear rack mounting points.
Fork 26" SUSPENSION FORK, ROCK SHOX DART2 W/TURN-KEY LOCK
ALLOY BLACK CROWN, adjustable preload, DiscBrake postmounts
Crankset TruVativ X-FLOW square taper or IsoFlow PowerSpline (cannot choose), Aluminum Triple 22/32/44T, 175mm
Bottom Bracket Sealed Cartridge
Pedals ATB Beartrap, resin body, metal cage
Front Derailleur SHIMANO DEORE FD-M510, Top Swing
Rear Derailleur SHIMANO DEORE SLX RDM-662SGS BLACK long cage (H normal / not rapidrise)
Shifters SHIMANO Alivio SL-M410 Mega 8 Speed STI Rapidfire Pods (24 speeds total)
Cassette/Freewheel SHIMANO CS-HG30-8I 11-30T
Chain 8 Speed Z72 Narrow
Hubs DiscSpecific Aluminum (black) Sealed Bearing mechanism
Spokes 14G Stainless Steel
Rims WTB Speed Disc Double Wall Aluminum disc specific
Tires WTB Velociraptor Blackwall 26 x 2.10 (front and rear specific tread)
Brakes TEKTRO NOVELA Mechanical Disc Brakes, Ventilated Steel Disc Rotors (round or wave/no choice)
Brake Levers TEKTRO MT2.1 for Disc with aluminum lever
Headset Internal Sealed bearing VP A71 1.125 inch
Handlebar Comp Aluminum Riser, 25.4mm clamp diameter
W:620MMxR:30MMx6 DEGREES
Stem Comp Threadless Aluminum 1.125 inch
Tape/Grip WTB Dual Compound Trail
Saddle WTB Speed V Sport with comfort groove
Seat Post Aluminum Micro-Adjust 27.2x300mm
Seat Clamp Aluminum w/QR
