I have an old bike that I want to convert over. Not sure how to go about making the crankset singlespeed. The arms that attach to the chain rings don't have screws holding them together. Is there a way to take it apart and just use the center ring? Or do I need new stuff?
Maybe a pic will help...
Sorry if these are retard questions...don't know much about the mechanical aspect of bikes
These cranks are spot welded to each other-no go houston. Square taper cranks are pretty easy to come buy on ebay and cheap- I would suggest, if your budget allows to upgrade to at least an isis or octalink compatible crank. Much stiffer for ss use. You will need a bottom bracket to upgrade.Full upgrade will run anywhere from 50-80 from ebay for a set up that you will be happy with.
Yea, the rings are pressed together. Cant take them off. Low end stuff is like that.
Luckily, it looks like it was inevitable.
When teeth of a chainring begin to have a shark fin or pointy profile to them (like yours do), they need to be replaced along with the chain, and probably the rear cassette.
SS cranks can be found for very cheap, but the only problem is installing them as it takes a special tool or two.
They say they recommend a 118mm bottom bracket. Should I get the spindle length they recommend or does it not matter since I'm using my free hub and can adjust the chainline with the spacers?
How do I know if I can get away with it? What do you mean replace the chain as I go?
On that note is there a different style of chain that I need for SS? I should probly use the search button for that but I already got the newbie thread goin...
You need to learn about chainline before you can pick your bottom bracket. If you're running a cassette hub in the back, you can adjust the chainline with spacers back there and don't need to worry about your bottom bracket spindle. But if you're using a freewheel it only has one chainline and you have to try to match it.
shorter spindle is stiffer. narrow Q. and if you ever decide to run a larger chainring and use the outer spider position, it will less likely to give you any troubles with the chainline.
do not recycle chains. its not that expensive.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
