I just bought a Onguard Pitbull Mini DT U-lock/cable combo. I would have prefered the non mini but the store only had the Pitbull in Mini and the Bulldog in Large which is not as highly rated.
The thing is I can't find anything that I can lock the bike to using it, either the pole is too big or the bike can't get close enough.
Am I missing something? This is my first U lock so I've never used them before. Should I return it and get the larger Bulldog model even though it's not as secure as the Pitbull series?
You could use the chain thing to wrap around large pole. I have the kyptonite series 2 which is pretty large and I can pretty much get that round anything.
Doesn't using just the chain defy the purpose of getting a u lock? The chain can probably easily be cut. I was hoping thr u lock could let me lock the bike to a pole and use the chain to secure the wheels, but I haven't found any poles that I could lock to other than stop sign style poles, and I read not to use that as a stop sign is just held by 2 easily removed bolts.
What type of object is a small u lock supposed to allow you to lock to? 'cause I haven't found any. Should I return it and get the less secure larger bulldog series?
Lock the rear wheel and something with the U lock. Wrap the cable around the front wheel and bike rack. The mini is more secure than the larger one, as it will provide a much smaller area to wedge a tool and use leverage to break it open.
Using both locks will give you the best odds of your bike staying where you left it.
I think U locks (especially smaller ones) are mainly designed to lock a bike to a bike rack, where the bike will be very close to the bars of the rack.
Well I went to most places I would normally leave my bike at and the only objects small enough to use the mini u lock on are sign posts like stop signs which can easily be removed with 2 bolts.
I'm quite sure I'll return this lock. Should I get a larger U lock which was of the less secure bulldog series or are those hex chain locks better?
I would not feel comfortable with only 1 cable lock 'securing' my bike. Of course I've had a locked up bike stolen out of my locked apartment, so I'm a bit paranoid.
So you went against everyones advice and you bought a lock that you don't even know how to use. Why do you make threads asking for advice when you don't even consider it? I'm not trying to be an a-hole, but I call it the way I see it. A beater bike or any bike instead of a lock that you cannot use would've been the way to go.
He didn't just buy it and check this guys previous threads. He's asked everyones advice about locking up his new Yukon f/s and we told him to get a beater, which he ignore and instead got a lock that's too small for him to use to lock up his bike. Oh well.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
