Thinking about building some newer and lighter wheels for my 29er. Currently have a Phil Wood Kiss Off Fix/Free coupled with a White Industries ENO freewheel. Nice combo to be sure.
Who else makes rear hubs (NON DISC) that are threaded for freewheel? I know that Paul Components does.
I have had several rear wheels with converted cassette bodies that use single cogs with spacers. I'm OK with that system but do prefer the ENO f/w.
How is the system that Chris King makes with the King cog and their spacers? Is the cog pretty solid in place or does it have lateral movement?
From my initial searching it appears that the system from Paul is the lightest but I'd love to hear your opinions as to reliability or other good options.
Paul is probably the lightest for a 135mm F/W threaded hub. Another one of the odd ball options is a True Precision hub. http://www.trueprecision.net/shopping/enter.html
Silent and the cog bolts on. That may be more to your liking.
The cassette hubs should have no lateral movement if you use a wide based cog and have the lockring torque to spec.
I've been using a Pauls hub with White Ind freewheel for about 18 months wih zero problems! I am having another set of 650b's built with Pauls as well.
I have a set of Paul hubs and love them. I will probably move away from them in my future build though, just because they do not have the color options I want for a disc hub. I actually contacted Paul to see if I could get some red ones and the answer was pretty much no. I also asked if I could just get the hubshell raw and all of the inner guts separately, so I could have them custom anodized. I was told they do not like to ship the hubs without the bearings installed. So I will move on from Paul with my next wheelbuild.
Paul, Chub, White, King, Ringle all make nice light SS hubs for freewheel or cassette.
If you're not concerned with newness you could look for American Classics and Bullseye hubs from the 80's and 90's on ebay. I've got a set of each I use on my SS commuter and cyclocross bikes. Both take thread-on freewheels and have been durable. the Bullseye has seen 3 different rim sizes since 1988 and hasn't needed bearings.
Chub hubs look really cool, are light and build a very strong wheel. Although they are disc the high flanges add a lot of strength, and you could always run a tomicog to have the flip-flop fixed option if you want. I'm running Phils but if I were going for a second wheelset those would be my choice.
errm... you mean the hub comes with disc mounts, and there's no version without disc mounts?
Because the rim you lace the hub to obviously is what determines whether the wheel is disc-only.
Thanks for all of the replies to date. After looking at my options and balancing the $$ cost vs. anticipated performance vs. weight, I think that I am going to give the Paul's Components rear hub a try.
Although I have always been happy with my White Industries ENO hubs, I want to drop some weight and Paul's design seems like a good one.
I would love to be able to get an I9 or CK wheelset for my singlespeed, but can't afford almost 600 for a hubset. I will probably go with a Hope Pro II hubset for almost a third of the price.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
