Give it time, Knowing Tyler its just a matter of time. Good to see he's back on the guide plates after 2+ years of them sitting to the side. Hes got skills and the sky's the limit with his potential and future! Good stuff to come!
pretty swanky stuff. but will it be worth the price? i hope so. ob is spot on. that with lg-1 bits would be nutty lite. a gamutt setup would take its own weight off the bike.
Well worth the price - at least for the people that would drop $400+ on a set of pedals (a set of which I REALLY want)
Ive run Tylers levers, pedals and new boxxer stem and beat the cr@p out of his pedals . Hit rocks hard enough to cause pins to angle in different directions and still no issues. Sent them back for a look after a year of abuse and the bearings were still spot on and the internals straight. Tyler regreased them and sent them back. My new pedals, levers for my Formulas "THE ONE" brakes should be here soon and of course Ill do a write up after abusing them again.
My stem when it got here!
So if the pins were bent, how could you screw the pins back out? cut them flush, back them out, and install new ones? Just curious before I pull the trigger.....
I weigh 235 lbs before gear and I smacked a pedal FULL weight into a rock (pedal slightly foreward so it hit and carried my weight up and off) and threw me and the bike up and off to the right. IT bent the the area of impact and the pins still intact. I dont run stock pins I swap them out for hollow allen pins sticking up 1/4" made of SS. They dont bend and the pedals were able to take punishment from a pin that it wasnt designed for! That says alot too me and is the reason Im getting another set.
Heres a pic you can see 1 pin there and that wasnt the hit point. I BEAT THE CRAP OUTA THESE!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
