I just got a diamondback with SR SunTour XCM202 front and Shimano Alivio rear deraileurs and I can't get it to shift properly. The chain either falls off one end, gets stuck in between two gears, or, even when it is working, it seems to take several pedal cycles to shift.
I've been using this: http://www.parktool.com/repair/readhowto.asp?id=75
but every time I fix one problem (the chain falling off on outside), another one seems to occur (chain rubs on inner side).
Is there any order I should go about adjusting it?
I know I could take it to a shop but I'd like to do it myself if possible.
