Lowering the bottom bracket was something people did on early models 06, not something Ive heard many do on 07s and 08s! [Turner improved these models anyway and GEO was adjusted for 07/08 models from by racer feedback by DT]
Check the data base there's the some info on how this is done for 06s and earlier models pretty simple and effective! :thumbsup:
when/if ya drill for a 13.9" b/bkt height, just make damn sure ya drill straight or itll be a battle to bolt in the link. also, pick the proper drill bit or you will have slop. slop is bad. mmm-kay? you may also need to shave the front down to clear the swing link/rear shock mount. this means the front munting holes are no longer useable due to the loss of material as you risk cracking the triangle. another thing i noticed is this will locate the h/ware on a surface with a few angles which would put a bind on said h/ware. i used a dremel tool to carefully flatten the area so everything sat flat and would torque up properly. maybe this is all covered in the instructions ta mentions above and i shoulda just kept my trap shut.
heres some pics of my drilled team spare. this thing is uber trick!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
