Ok, so here's the deal, I would like to upgrade my 2008 GT Avalanche bike.
What I would like to know is that if the following components will fit fine on it.
2009 Fox 32 Vanilla R Fork
Travel: 140mm
Adjustability: Rebound, Coil Spring Preload
Spring Type: Coil
Steer Tube Diameter: 1 1/8"
Axle Type: Quick Release
Brake Mount: Disc Brake Only (74mm post)
Color: Black
Weight: 4.16 lbs
And the Shimano XT Groupset.
Also here's the spec for my bike.
PRODUCT SPECS
Stem:
GT ATB, threadless 25 degree rise with four bolt alum face plate
Nipples:
Brass CP
Spokes:
Stainless steel 14 gauge
Chain:
Shimano
Rear Cogs:
Shimano Eight Speed, 11-32 ratio
Front Derailleur:
Shimano M -330
Pedals:
ATB Resin body, Steel cage, toe clip compatible
Bearings:
Cartridge Sealed
Saddle:
WTB Speed V saddle
Seat Post:
Micro-adjust seatpost
Handlebar:
AL ATB riser bar
Wheels/Tires:
Alex ACE-17 double wall rims; alloy disc hubs; Kenda Nevegal 2.1" tires
Brakes:
Tektro IO mechanical disc brakes
Crankset:
Suntour XCT-02, 42/32/22
Suspension:
SR Suntour XCM fork with lockout, 100mm travel
Drivetrain:
Shimano 24-speed drivetrain with Alivio rear derailleur; Shimano Alivio shifters
Grips:
GT Dual Density ATB
Headset:
Tange Seiki system for 1 1/8"
Seat Clamp:
GT Forged Alum QR
Frame:
GT Triple Triangle design 6061 aluminum with Hydro formed downtube, zero stack headtube. Disc compatible with removeable der. hanger
GEOMETRY
FRAME SIZE: Medium
HEAD TUBE ANGLE:
71°
SEAT ANGLE:
73.5°
CHAINSTAY LENGTH:
420mm
STANDOVER HEIGHT:
734mm
HORIZ. TOP TUBE LENGTH:
577mm
SEAT TUBE LENGTH:
466mm
HEAD TUBE LENGTH:
130mm
BOTTOM BRACKET HEIGHT:
298mm
WHEELBASE:
1051mm
FORK LENGTH:
429mm
RAKE:
41
Travel: 140mm
Spring Type: Coil
Color: Black
Weight: 4.16 lbs
PRODUCT SPECS
Stem:
Nipples:
Brass CP
Spokes:
Chain:
Shimano
Rear Cogs:
Front Derailleur:
Shimano M -330
Pedals:
Bearings:
Cartridge Sealed
Saddle:
WTB Speed V saddle
Seat Post:
Handlebar:
AL ATB riser bar
Wheels/Tires:
Brakes:
Crankset:
Suspension:
Drivetrain:
Grips:
GT Dual Density ATB
Headset:
Seat Clamp:
GT Forged Alum QR
Frame:
GEOMETRY
FRAME SIZE: Medium
HEAD TUBE ANGLE:
71°
SEAT ANGLE:
73.5°
CHAINSTAY LENGTH:
420mm
STANDOVER HEIGHT:
734mm
577mm
SEAT TUBE LENGTH:
466mm
HEAD TUBE LENGTH:
130mm
298mm
WHEELBASE:
1051mm
FORK LENGTH:
429mm
RAKE:
41
