i need to service my shermans(slider)&(firefly) i dont want to send them away so i wanna do it my self. i know there has been threads on this but i couldnt find them. so if someone could give mye some insight on how to work on them that would be great
It's incredibly easy, pretty self explanatory when you take it apart.
The semi bath oil is seperate from the damper oil. Usually the oil stays pretty clean in the damper. The semi bath is for lubrication purposes only... I seem to recall something like 15mL... but could be wrong. Put back in whatever comes out. The damper oil... I thought was 30mm from the top... again, could be wrong. There's a service manual for it floating around...
The damper oil is Motorex 5wt. You can use a synthetic motor oil (without seal swellers) in the lowers for the semi bath. Clean out the gunk from underneath the seals and repack them.
Pop off the top cap on the damper side. Turn the fork upside down over a basin. Cycle the fork a few times to get all the oil out.
The rebound leg... remove the rebound knob at the bottom then insert a 10mm (?) and turn clockwise, this one is reverse threaded. Undo the footbolt on the other leg. The lowers should come right off. There should be no need to touch the spring side of the uppers, just the damper side. Now you can replace the semi bath, repack, and replace seals/bushings if necessary.
So tonight i tore into my firefly i had only one thing that i messed up on. for some reason i tried to thead on the spv rod out the wrong way and it broke half of the theads off. i still got the oil changed on the fork and got it back together but now the pressure leaks out of the messed up theads. so what do i do now about the jacked theads? Also do you only have to put oil in the lowers or is there any where else you have too??
The same thing happened to me, I'm trying to find a cartridge too so if anyone nows where to get one, it would be appreciated.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
