I'll start off with a big thanks to Dianna and Ryan and the crew over at Astrix. Super nice people to work with and the quality and ride that comes from their products is amazing!
First up is the slalom/4x/urban/dirtjump/jack-of-all-trade's Astrix Union
Build Specs:
Frame: Astrix Union
Fork: RockShox Reba Team (dual air, U-turn)
Headset: FSA Cratridge bearing (not sure which model)
Headset spacers: Winwood carbon fiber
Compression device: THE headlock
Stem: Race Face Diablous
Handlebars: Race Face Next Carbon Low
Grips: ODI Ruffian Lock On
Brakes: Avid Juicy Carbon w/Ti hardware, 7" front 6" rear
Shifter: Sram XO trigger shifter
Derailleur: Sram XO short cage
Chain: Sram PC 991 Hollowpin
Cassette: Shimano XT 11-32T
Sprocket: Race Face 36T DH
Crank: Bontrager RaceLight SS
Bottom bracket: FSA Platinum Ti ISIS
Chain guide: Gamut 36T
Pedals: Wellgo MG1
Seat: Bontrager Inform RL
Seatpost: Bontrager Race X Lite ACC carbon
Seat clamp: Bontrager Carbon Friendly
Front hub: DT Swiss 440FR
Rear hub: DT Swiss 440FR
Spokes: DT Swiss Champion Double Butted
Nipples: DT Swiss Brass
Rims: Halo Freedom Disc
Tubes: Bontrager 24x1.95 standard
Tires: Kenda Nevagal 2.35 Tomac Stick-E front and rear
Frame: Astrix Havoc medium
Rear Shock: '08 Manitou Revox w/250# Ti spring
Fork: '08 RockShox Boxxer WC
Headset: Race Face Deus
Compression device: THE Head Lock
Stem: Sunline Inegrated
Handlebars: Sunline V1 710mm+ wide
Brakes: Avid Juicy Carbon w/Ti hardware 8" front, 6" rear
Shifter: Sram XO gripshift
Cassette: Shimano Ultegra 11-25T
Chain: KMC K10SL (10spd machined links, hollow pins)
Crank: Bontrager RaceLite SS
Bottom bracket: FSA Platinum 100mm
Chain guide: MRP G2
Pedals: Welgo MG1
Seat: Bontrager Inform RL or Bontrager Race X Lite
Seatpost: Bontrager Race X Lite ACC Carbon
Seat clamp: Bontrager QR Carbon Friendly
Front hub: WTB SuperDuty 20mm
Rear hub: WTB SuperDuty 150mm
Spokes: DT Swiss AeroLite
Nipples:DT Swiss Alloy anodized red
Rims: WTB LaserDisc FR
Tires: Michelin DH16 A/T 2.5 front, Michelin DH24 A/T 2.2 rear custom cut
I've been really pleased with the performance of both bikes. The union is sitting about 27lbs and is a blast to ride everywhere. The Havoc is a much funner bike in everyway than my last bike('07 M3). The Havoc has a longer wheelbase, slacker head angle and weighs more than the M3, however the Havoc is far easier to whip around, is much more stable, far more compliant to the ground and the floating rear brake leaves me with a huge smile on my face with the suspenison remaining alive with the stoppers on.
There will be a 3rd Astrix added to the mix soon to fill the gap between the Union and the Havoc. Suspension will again be Rockshox (likely in the form of a Lyric), shifting will be Sram X9(I've got a couple of those setups so I may as well used them), brakes will be either Juicy Carbons or El Camino's both of which I have already or I may branch out and try the new XT or Strokers. I will again be building a custom wheelset for myself. The AeroLite spokes turned out really nice on the DH wheelset so I will probably go that route again. We'll see what time and money allow for.
-Kevin
Build Specs:
Frame: Astrix Union
Pedals: Wellgo MG1
Chain guide: MRP G2
Pedals: Welgo MG1
-Kevin
