alrighty so i have a roco tst on a bottlerocket and i was wondering what exactly the air is for in it. i have it at just about 200 right now, it says minimum 180 on the shell. in the manual it says 146-178 so i am a little confused. if i lower the air what will it do/if i up it what will it do. i am 240lbs if that matters. a little confused the manual dosnt explain it much, is it bottom out resistance like a fox, its just called compensator air in the manual?
i am also running a 66rcv and it has air preload should i run much in there. i put like 5 pumps in it so it just registered on a low psi pump. the sag is good with or without air in it. i just feel like it tops out a little softer with air in it.
any help is appreciated this is my first full squish and i want to get the suspension set up right but im having trouble.:thumbsup:
