LG-1 and chainring question
403 views 5 replies 3 participants last post by  njhcx4xlife
#1 ·
so i just picked up and lg-1 and need some help. I am currently running saints with 2 rings and a bashguard. I'm assuming that I will need to run my chainring where my bash guard currently is with the lg-1? I've also hear you have to grind off the small ring hole to fit the guide...is this true? Last question is what are some good and light chainrings to look at with this set-up and what bolt pattern am I going to need? Thanks.
#4 ·
I know the lg-1 is a single ring guide...I'm converting to a single ring
with that being said I was tring to figure out which ring to run and what the bolt pattern was because i wanted to order a ring and am at work and don't have the bike in front of me...So I need a 104 ring and my question is it goes where the biggest ring or bash guard would normally go when used with the lg-1 right?
