Guys,
Any advice on boost valve pressure? I have two DHX's, a 5.0 (on my Enduro) and a 3.0 on my Sunday. Both are Ti coil.
Trying to get the setup right - but Fox gives few pointers on the boost valve pressures. The range is 75-200psi. I started with 100psi (I weigh 150lbs, 160 with gear) and the thing feels lovely and soft but sags badly half way through the travel and bottoms out often, particularly on the Sunday. Spring rate/sag is correct BTW, if anything, slightly too stiff so it's not that..... feels more like a lack of compression damping to me.....
Changed it to 150psi - thing feels uber harsh. Is this right? Is the range so delicate? Am going to try 125psi this weekend coming up - but what pressures are you lot running? Do you notice any great differences?
Thanks.
Thanks.
