you will hate that chainguide! I had it and it sqeaked sooo much. at first i thought it just need to be broken in but it persisted for ever. Finally i removed the top black park and just left the roller on bottom. I would not buy that. two rollers would work better.
I have heard they work well. I don't see how the top piece would squeak since it doesn't even move. Most guides don't use 2 rollers either so I don't quite understand Hab1b's complaint. If it did squeak from the roller it doesn't seem like a problem a little lube couldn't solve.
Thanks for the replies, but will it fit on the bike? That was my question....
I might be able to get one cheap, so it will be worth trying, anyway. I really dig the double bash ring/dual roller setups, but ffs, I don't wanna shell out that kinda cash right now.
I have seen them on similar designs to the 77 so it should work. I had a shift guide on a a bike almost identical to the 77 so I would say give it a shot.
ok so i did a poor job of explaining the issue. basically the problem i had with it is this. The Top piece sits on the chain and the rubbing causes a annoying creaking /squeaking noise. I raised the top piece up so it wouldnt be on the chain and it worked for a little while until i started hitting some drops then the top peice just slid down again and was sitting on the chain. Two rollers is obviously not the standard, i was saying you would be better off with 2 rollers than that top peice. try it out if you want. maybe i got a bad guide, all i know is it was creaky and then i took it off the creaking stopped.
Makes more sense now...weird still but makes more sense. I've never heard of that happening but i'm not calling BS either. Atleast you solved the problem.
NO DUDE!! Get a ****ing e.13 with the saints on the session, its is the dopest set up. i rode it on a session wiht saints for dayssssss, and i now run one on my session 10
Give me your paypal or credit card information, and I'll order one up for myself right away!! Thanks!
:thumbsup:
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
