I have a pair of new crossmax xl and I was planning on mounting regular tires with sealant.
Should I also use stans rim strips or will my tires hold ok without them.. The tires are new conti escape and explorer. I will be using slime instead of latex .
If I remember correctly you do not need rim strips on these wheels because the rim is already a sealed UST rim. Some one please correct me if I am wrong.
The only reason I can think of why you would use them is if the strips helps lock the standard tires in and sell the bead better. But I dont think so
you don't need Stans rimstrips as the rims are already sealed.however without any rimstrip you will have a hard time getting the regular tires seated and inflated.
the Eclipse-UST-Tubelesskit ((M426) has that special "foam"-rimstrip which helps inflating regular tires.it weighs just 4g and does nothing else than help get the tires inflated.
you may have luck and the tires go on without anything but you definitely need a powerful compressor to inflate then.
here's the Eclipse "foam" rimstrip installed on a Crossmax rim.you can also see the special Eclipse valve which fits Crossmax rims and allows you to insert sealant through the valve stem:
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
