I have outlaws, but since weyless is discontinued, I cant get the 12mm through axel drop outs. I would love a 10.mm setup, cause then i could rock a bolt on...
I don't think they do, But I have been considering grinding my drop outs down 2 mm so the 12 MM axel will fit. But with the weyless dropouts, they are removable and made outta hella think aluminum
still waitin for someone that knows, i thot i saw that someone had a set up like that
edit: i think my axle may be bent because when it is loose i can rotate the tire a half rotation and it will be tight. so a new qr rear set up may be in order...
I am running them that way.You need to make the QR to12 mm convesion then get a 12mm axle with a 10mm STEPDOWN. You can get them from Azonic directly works great, though Azonic is a bit slow on the shipping.
just go to azonic's website, or do google search. get the 12mm axle w/10mm stepdown. I did this to my bullit with the azonic outlaws. works like a charm! easy installl too.
I am running the 10mm bolt on and like the others said, just set it up for the 12mm thru-axle and then order the 12-10mm step-down axle from Azonic. There is no bearings to change. All the hardware except the step-down axle should have came with your wheels.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
