I finally broke my one time use Mineral oil syringe that came with some bleed kit.
That new Park Tool set is nice but way past my needs and wallet size.
What is someone using for a more sturdy and long lasting syringe?
The syringes sold in the brake bleed kits including Park's are typically veterinary dosing syringes. There are many Chinese knock offs but you can go with the French made Ardes brand which usually ships with spare o-rings and is made from polycarbonate and nylon on the plastic parts. The metal is nickel plated brass. These are designed to be re-used and are well made. The o-rings look like silicone. They are easily disassembled and cleaned. They have Luer lock barrels for attachment of needles etc.
I suspect the bike versions are Asian copies but I have the Ardes and they are high quality. You can find them on line at livestock supply and Amazon.
There are lots of mineral oil bleed kits starting pretty cheap on Amazon or eBay. Jagwire makes a nice universal mineral bleed kit that covers just about all mineral oil brakes from the various manufacturers. They also sell the various fittings and hoses as well.
The typical cheap syringes you can get a pharmacy have rubber pistons that will swell and stick after using mineral oil in them. They are pretty cheap so can be bought in quantity and thrown away after use.
I missed this post this thread when it was originally posted, but there are a bunch of relatively inexpensive bleed kits on Amazon now that provide what look like decent quality syringes in them that can be properly disassembled and cleaned between uses. As an example, something like this for Shimano brakes. I ordered a similar one for bleeding DOT fluid systems and have been impressed - these syringes feel night and day better than the typical single use syringes that I've used in the past.
I should have mentioned that brakes in my case were/are Magura and Formula. Suspension is Torco and WPL oils.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
