So I am strongly leaning towards picking up a vintage rigid MTB to make into a gravelish/commuter/off road touring bike. I was thinking of running something like Velo Orange Crazy bar or Moloko bar on it (rather the drop bars) but my question is with sizing. I am 6'2" so I am thinking I need 21" or 22" bike but given most of my experience is on BMX (where sizing only kind of matters) or on modern MTBs (which have much longer reach) I am wondering how to make it seem comfortable. I have a cyclocross bike but no matter what I do I can't seem to get comfortable. I somehow feel both too cramped and stretched out all at the same time.
Am overthinking it? How do I get comfortable on a vintage MTB?
A vintage MTB frame will fit similar to a cyclocross frame for a given size.
Contrary to the hype "modern geometry" doesn't have a longer reach. The dimensions and angles are so jacked up that there is no apples to apples comparison. But frame size for frame size my 1991 Stumpjumper has a longer reach than any mass produced frame today.
At 6'2" something around 21" is a good starting point. A 120mm stem is also a good starting point depending on the shape of the bars you may need a longer stem since tiny road bars are the hype now.
From wha i have seen around, modern MTBs don´t fit your body; they fit the terrain... you ride a modern mtb by constantly throwing your weight around. A dropper post is an evidence: your saddle is either on extreme climbing mode or you stand on your pedals only. You are never balanced for everything. They say it´s fun. Fair enough.
Vintage mtbs fit like you need when pedalling hours traveling the distance but at the same time letting throw your weight around when descending tricky technical terrain. It´s a hard fine balance and the best builders made it happen. Ride a vintage Fat Chance in the woods and it becomes clear.
My standard for stem length is 130mm since i have a long torso and size my bikes for leg length. A 130mm stem works well w/ a 71degr head angle and a 23in handlebar. I don´t use bar ends. I run away from susp forks. They do nothing for me. An early 90s late 80s mtb is the perfect tool for my job.
NOt easy to find the perfect fit but worth trying as many bikes as possible.
I am not really looking to open the debate on newer geometry versus older. I'll just say that my 64deg head angle, 475mm reach hardtail is the most comfortable and fun mtb I have owned (out of a Cannondale Trail 7 and a Niner WFO9) or demoed. But do I really need a 150mm of travel for around town and on gravel no.
I am looking for something that will be fun to build up (I like building stuff and looking for deals), cheap (so I am not as worried about it went I lock it up) and I appreciate the history of MTB so having an older bike would be quite neat. Plus it is a bit of a change of pace.
Every brand and model has it´s own fit. A Kona or Klein won´t fit like a Ritchey. Find a bike, check the geo numbers (google may help) and compare to your current fit.
There is no golden rule for every brand making it fit the same. DEcide bike first then look for your size in their line up.
I have a 1996 Moots YBB that I have considered making into a gravel bike, but I would be stuck with 26" wheels because of the rim brakes. Are there any decent gravelish 26" tires available? My rims are 17mm internal, so they could take a pretty narrow tire.
One of the reasons not to do this is the lack of availability of tires and rims.
I was just under 6'2" the last time I stood up really straight at the doctor's office without shoes on. The answer for me is 22.5" - 23" vintage MTB frames.
My main ride is the 22.5" black and red MTB in the rear. That has a tall stem with 80 mm reach if I remember correctly and an On One Midge bar.
The green one in front is a 23" that I messed around with for a short time before getting rid of. That stem combined with those particular bars would have been too long a reach for me, from just sitting on it in the garage, but I liked the fit with the original flat bars and that stem for city and gravel riding. I bet it would have worked great with a shorter reach stem and dirt drop bars where the hoods and drops aren't so far away.
Don't know if that's of any help but I always like reading how tall people are when they post pictures of bikes - I think it helps me judge sizes on bikes I see for sale on craigslist when they're not listed.
Have you used a layback seat post? That is assuming that you have played around with stem lengths and such. I found with the bars with sweep like you are asking about I like to run a longer stem "90+".
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
