Finally removed all evidence of V-brakes from the Goat. Added some black Suntour brakes & hangers to match the rest of the build. Looks much better now.
I would like some advice on setting up the brakes & pads. Any best practices out there to easily set toe & all that would be much appreciated.
Use a business card on the rear of the pad to set toe in. Some pads, like Kool Stop have a slight ramp on the rear to make it easier. Here's another resource.
Getting the cables right - de-burred and properly round - plays a big part in this. Sharp cutters are key.
Assuring that the brakes are a good fit on the posts is also important. Filing a post where necessary can result in less play and better, more positive, contact.
Last tip I have is using a brake that has no tension you are setting the pad. With internal springs (like your Suntours), try taking the spring out until the pad is set just right. With Paul brakes (my fav) or old post-mounts, the disengagement is easy and makes perfect toe and placement easy.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
