my bike is a 2013 kona splice setup with a 3x8 system. right now I've got a 16t cog conversion kit, a black spire stinger,( as my chain tensioner), narrow chain ring nuts, kmc 710 half link chain and a blackspire 96mm abcd narrow wide m8000 ring gear. problem being the asymmetrical bolt pattern.
now I was told half links aren't that good of a chain to have and that with singe speed a narrow wide isn't needed, but I am limited to a 96mm bcd with my current shimano m612.
Ya just there isn't a whole lot of selection with 96mm bcd. narrow wide is my only option feesably. And that i bought the m8000 chain ring itd be cheaper in the long run to get the boost spec crank set.( on the principle of building a boost spec as hardtail in the future)
so I'd like and think that using boost cranks with a ss will work. Since boost would need less outward shiming for proper chain line right?
Ditch the half-link chain and get a normal KMC Z610. You don't need a narrow-wide chain-ring, but it won't hurt as long as your using a normal chain. I'm running them on my single speed and my dingle speed because they were the cheapest option.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
