Worn Bushings/Bearings- Mtbr.com
Results 1 to 7 of 7
    Reputation: nicpie2468's Avatar
    Jun 2015
    I just noticed that when i pick the back of my giant trance up i can feel a little play in the linkage. Ive had the bike for over a year so i assume its time to replace the bushings/bearings???
    If so it okay to ride the bike still??? I plan to get them changed but i had rides planned in the next couple of days and i dont think my lbs has a full set of bearings/bushings in stock atm.
    Fat-tired Roadie
    Nov 2007
    Check the torque on all the bolts before you overworry. You could just be feeling something loose, rather than something worn out.
    That said, I think riding something worn enough to have play is a Bad Idea. Impacts are a lot harder on pivot pins and bearing seats than the more moderated shocks they experience if everything's working right.
    Sent from my E5803 using Tapatalk
    Jan 2014
    Quote Originally Posted by nicpie2468 View Post
    Most likely one or both bushings need replaced. They cost a couple bucks each plus installation if you dont do it yourself.
    Other than that the most likely thing is your pivots need adjusting.
    Of course there are more complex things that could be going on but less common.
    Fix it now.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Generally no, it's not a good idea to continue to ride when you notice looseness, because that means a surface is constantly slamming into another surface while you are riding, resulting in elongation or ovalization of the bearing receptacle and putting stress cycles on things like bolts and linkages. Can lead to permanent damage.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Do you have the new Fox igus bushings or DU Bushings?
    fuggansonofahowa
    Reputation: Hawseman's Avatar
    Good question. More times for me it was the shock's DU bushing causing play. My bike frames have always had sealed cartridge bearings, not bushes. That could be a good reason.
    Unless you ride incredibly hard and multiple times a week, it's unlikely that a year old giant blew out it's bearings already. Your shock mount bolts are likely loose.
    Do the same pull test, but with a hand on your upper shock mount and check for play by hand.
  1. Worn bushings. What are my options?
    By MikeyP2106 in forum Shocks and Suspension
    Last Post: 03-09-2015, 03:02 PM
  2. Replies: 2
    Last Post: 01-10-2014, 01:56 PM
  3. Worn shock bushings on TBc, again!!
    By BLUR'b in forum Santa Cruz
    Last Post: 09-06-2012, 05:16 AM
  4. Worn bushings on Revelation RLT Ti?
    By jeffgre_6163 in forum Shocks and Suspension
    Last Post: 09-09-2011, 06:06 PM
  5. Are my fork bushings worn-out?
    By bwalton in forum Shocks and Suspension
    Last Post: 05-06-2011, 10:51 AM
